Go to Post So measure not by the masses, but by the sparks that you generate. - Kims Robot [more]
Unread 24-03-2010, 00:44
Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Small FMS timer bug
This is very interesting. I will time some matches during the Boston Regional to confirm this "on the ground". Watching recorded matches may introduce issues with different frame rates due to re-encoding, but it sounds persistent.
Unread 24-03-2010, 00:53
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Is this a bug that should get squashed before this year is up? I know the obvious answer is yes, but technically it would be unfair to teams playing in later weeks..
Unread 28-03-2010, 16:05
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Yes, identify and fix the bug, but implement it in next year's FMS. Leave it alone for now. We've all had enough changes already.
Actually, I was thinking this weekend that the matches were too short, scores were too low, and how would strategy change if the drivers had more time... But that's a different question!
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 24-03-2010, 04:26
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
From Dave Flowerday's post, he timed matches in-person at the Midwest Regional, confirming his observations from the Milwaukee webcast. From the perspective of fairness, if all the matches run the same duration, no advantage is gained or lost* by any teams.
Maybe FIRST will discover a mini-black hole in the FMS that dilates time and create other problems with the field?
*Unless, of course, you don't trust your drivers and have automatic timing features in your code that effectively ends your match earlier than the rest of the field. (Sorry, Joe!)
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 24-03-2010, 08:54
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
First, putting the brake on is not "ending the match early." The code I want to implement will allow the winch to go UP but not DOWN during the last 3 seconds of a match.
Second, I trust my drivers. BUT if there is a way that I can unload them from having to think about details during a match, I'm going to do it, especially given that we have not had enough quality time with the robot to practice these kind of things.
From years of experience, I can tell you that drivers get overloaded pretty easily. There is a LOT going on out there on the field. On something as critical as this, I think an auto engage is a good idea.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 24-03-2010, 10:05
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Hmm. The LHC was recently re-started... coincidence?
FMS Light 2010? alectronic General Forum 1 04-02-2010 09:28
Finding FMS Lite Jon236 Off-Season Events 5 29-09-2009 13:44
[FTC]: FMS saaby FIRST Tech Challenge 4 02-02-2009 17:12
[FTC]: Field Timer (similer but not the FMS) team2845 FIRST Tech Challenge 0 19-12-2008 17:52
Small bug Jay Lundy CD Forum Support 1 18-06-2001 17:03
