command line input...
This is going to sound very very crazy but...
Is there a way for a text input to be taken into the robot from the DS and have it function like a command prompt of sorts, ie. we have a function called runmotorx that takes in a float so we type in runmotorx (float value) and it takes it in and executes it. is something like this done with reasonable ease? hopefully with out 100's of if statements. any ideas on how to do this? |
Re: command line input...
can it be done? yes
is it competition legal? most likely not what would you need to do? lots you would need to manage a socket connection, and listen for incoming data, once you heard the enter key, the proceed to a switch or if's which would get the first word, and call that function (optional), then process the rest of the input and do the function. why you would want this (aside from the coolness factor) is beyond me. unless you have a expert typist, i would not want to control a robot like this this would definitely go in the summer project bin Last edited by byteit101 : 24-03-2010 at 15:40. Reason: typo |
i was more thinking as a debugging tool, think about it, instead of having to remap buttons to do certain functions especially for debugging you could just type in the command and away you go,
the hangup on me just going off and playing is i have no idea how to evaluate a text input without large amounts of if statements which i was hoping to avoid, as for it being legal, if it was in the bandwidth for the dashboard wouldn't it fall in under the rule of being able to modify that code? |
If it is for debugging, why do you need to enter it through the DS? I was planning to develop an interactive debugger through the debug console (i.e. give you a prompt so that you can enter some debugger commands to the robot to do things such as turning on tracing, changing PID constants without recompiling code, dump some important states on demand etc.). But I do not have time to do it this season. So may be a summer project... The only difficult part was to figure out how I can prevent the input go into the cRIO kernel debugger instead of my interactive debugger.
You could probably bypass the whole socket/command-line thing and have it periodically check the robot's local storage for a text file with a certain name.
Something like Code:
while(true)
// not shown: feeding watchdog or disabling it
ifstream in;
in.open("commands.txt");
while(!in.fail() && !in.eof) // if we managed to open the file, and it has contents...
int motorChannel;
float motorPower;
in>>motorChannel; // loads the channel we want to output on
in>>motorPower; // loads how fast we want to run the output
PWM pwm(motorChannel); // declares an interface to the channel
pwm.Set(motorPower); // outputs the desired amount
Wait(5.0); // lets it run for awhile
pwm.Set(0.0); // turns the motor off
Wait(5.0); // don't constantly check the storage device.
The commands.txt file would just look like <motor channel> <motor power>. i.e. Code:
4 0.5 4 -0.5 3 1.0 3 0.5 3 0.25 3 0.0 |
the reason for not using a command text file is that it requires a specified format, and order for the inputs, if any functions are added then the function that needs to read in the text file will also have to be changed, and it will always run everything in it, as for the input not having to be on the DS, no it doesn't have to be but i figured that since it already is connected to the robot, it couldn't hurt to use it over another laptop, but in the long run i don't think it matters
What you can do with it is execute the same commands you would execute at the vxWorks shell prompt -- no more. The text file(s) need to be in a file system -- FTP them. It is not junior programmer stuff though and the interpreter doesn't know how to parse floating point arguments :-(. Search through Workbench Help for "shell commands" and "ptyDevCreate'. Unless you are very good *and* willing to work very hard, you probably won't be able to utilize it this year. Consider making it an off season project. I can help you with it -- I have example C code I can share. If you want it, send me an email gvarndell@hotmail.com Last edited by gvarndell : 25-03-2010 at 11:26. Reason: clarify, offer real help... |
willing to work hard check
very good, not so much, Thanks for the help |
I've got a web server running on our robot, allows us to change values and stuff like that. No text input at the moment, but doesn't mean you can't extend it to allow it. *Extremely* useful for debugging.
http://code.google.com/p/webdma/ |
#10
Surely you are aware of the NetConsole application... it is a C interpreter that allows you to call C entry-points directly. It is not competition legal.
You can also use the dashboard video tcp connection, but that will require you defining your own set of commands (your many if statements). This is competition legal, but more work. |
#11
Does it parse floating point arguments? It's just a shell with re-wired stdin and stdout, right? |
#12
| Dashboard command line? | Phoenix.14 | Programming | 3 | 13-03-2010 10:13 |
| command listfor c??? | jfrank | Programming | 12 | 22-01-2008 20:16 |
| assembly command | tseres | Programming | 3 | 18-01-2008 08:13 |
| 2.5 is alive !!!! (input ! .. more input ! ) | Lloyd Burns | Programming | 2 | 14-01-2003 19:15 |
| New Line Input Parsing | Trashed20 | Website Design/Showcase | 6 | 30-09-2002 10:46 |
