Go to Post I'm tired of quoting the manual for today so all I will say is "Try again". - Vikesrock [more]
Unread 24-03-2010, 15:40
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Engineering Challenge- Spring Loaded Kicker Edition
Working through a possible issue with our practice bot, I thought it made an interesting engineering challenge.
So you are at competition with your spring loaded kicker.
You have a motor that winds the kicker to the motor/gearbox stall point (motor stops before mechanical limits) with a quick release mechanism that allows the kicker to kick. You kick several shots and notice that the it would be good to kick the ball a little further (about 10%). All you can do is add or subtract spring rate. Should you:
A. More spring rate = more betterer!
B. Less rate is more when it comes to springs!
C. Nothing, no matter what you do it will stay the same.
D. Ask the pit admin for some of those frictionless bearings you've heard so much about.
E. Blame the programmer.
Please do the math:
spring loaded launcher sciguy125 Technical Discussion 6 17-01-2006 22:42
Spring-loaded claw Anubuss Technical Discussion 8 21-01-2005 15:32
Legality of Spring Loaded Pistons Yan Wang Pneumatics 13 19-02-2004 17:20
Spring-Loaded Pistons TwoEdge47 Rules/Strategy 2 30-01-2003 21:36
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
