Go to Post DonRotolo used COMMON SENSE. ... ... FIRST/Chief Delphi Community fainted! - PayneTrain [more]
Unread 24-03-2010, 19:44
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
cRIO issues (Imaging and deploying)
Part I:
Team 1713 recently saw a complete cRIO failure - somewhere in the power block seems probably. We contacted NI, and they were absolutely excellent in getting a new one to us ASAP. Our problems started last Friday, and we already have the replacement.
Thank you, NI.
Part II:
The new cRIO was imaged and formatted to Java, then code was deployed. The deploy failed, giving a message about a line in the build.xml file, which when followed, read:
Code:
<antcall target="-do-jar-and-deploy" />
After a little looking around, I tried to reimage the cRIO, but the imaging tool couldn't find the cRIO, even though the connectivity light was on (Ok, now I think to ping it, but I didn't then). The computer's IP address was correct. I'll edit in the results of the ping tomorrow.
After a few searches, I couldn't find anything similar to this problem. Has anyone else had it, and how have you fixed it?
Thanks for your time!
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
cRIO Imaging MHSrobotics2853 Electrical 3 02-02-2010 00:43
cRIO Imaging Error Scip Programming 1 20-01-2010 21:48
cRIO imaging alex42 FRC Control System 3 16-01-2010 20:05
cRIO imaging tool dnrobotics11 Programming 4 14-01-2010 23:32
cRio, ethernet, and DS issues .. (was: HELP!!!!) tomy FRC Control System 5 13-01-2009 21:25
