Go to Post We are different, on purpose, for a reason. No one in FIRST should EVER forget that. - Rich Kressly [more]
Unread 25-03-2010, 11:02
May_Walter's Avatar
May_Walter May_Walter is offline
Artemis #3083
FRC #3083 (Artemis)
Team Role: Coach
May_Walter is an unknown quantity at this point
cRio not on
Hi, while driving our robot, we suddenly lost communication, then we checked the robot and saw that the (-) cable of the cRio was disconnected. we reconnected it and the power light of the cRio was off..... we just don't know what could have happen! help?
and another thing.. today before that happened the robot didn't show the voltage level on the PC classmate... don'tknow if it means anything..
Thanks
Team Artemis #3083
Team ARTEMIS - #3083 - The Sky Isn't The Limit Anymore!
2011- FRC Team Captain and Coach, FLL mentor & Ref. Semi-Finalists, Motorola Quality Award, Star of the Day.
2010 - FRC Team Captain and Coach, Engineering Inspiration Award, UL Industrial Safety Award
2009 - Coach, Judges Award, Finalists w/ 3075 & 1690
Unread 25-03-2010, 11:25
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: cRio not on
If you had something pull hard enough on the wires to pop one out, you likely popped the other one out too. It could be just barely out, or internally broken.
Check your wiring visually, and then use a multimeter to check voltages.
Unread 25-03-2010, 11:47
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: cRio not on
If the negative wire was free to move around, it could have touched the positive contact and shorted the 24 volt supply from the Power Distribution Board. Verify that you still have 24 volts present at the cRIO's power connector.
Unread 25-03-2010, 11:52
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
Team Role: Coach
Re: cRio not on
we still have a 24v call, but we checked all the wiring and it was ok
Unread 25-03-2010, 12:24
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
Team Role: Coach
Re: cRio not on
another thing.. we connected it originally v-v and c-c but the wiring datasheet says nc-c and v-v... that's not making any sense.. specially because it worked with v-v and c-c.....
cRIO not turning on!!! MHSrobotics2853 Electrical 14 18-02-2010 08:58
cRio not detected... 3195mentor FRC Control System 6 12-02-2010 01:29
cRIO Not Working?!? JohnFogarty Electrical 6 17-01-2010 15:53
cRIO Not Working?!? JohnFogarty Control System 2 17-01-2010 08:33
CRio Not Responding Shadow_Cat NI LabVIEW 7 13-02-2009 08:12
