Go to Post "It's not a weapon, it's an active bumper system." - Ameya [more]
Unread 26-03-2010, 00:52
Kyledoo Kyledoo is offline
FRC #2603
Kyledoo is an unknown quantity at this point
Arm motor not moving at full strength, recalibration necessary?
Hi all, we are competing in our second regional of the season this weekend(Buckeye) and we are having a little problem with our lifter arm.
When trying to control the movement of the arm up or down we are not achieving full power output. We can tell this because on the Dashboard feedback, the bar only goes about half as high as bars for our drivetrain. We have tried using both joysticks and buttons and everything gives the same results. We are programming in C++ and to set the power of the arm we simply declare the Victor as arm and then do arm->Set(stick2->GetY());
I was thinking there is some sort of calibration that is off, and don't know if this is a programming fix or the "hard reset" that I have read about when you recalibrate the victor using the reset button and some hard-coded values.
We applied battery voltage directly to the motor and it moves at the right speed.. Any help will be greatly appreciated!
CIM Motor Strength nskerven General Forum 15 19-03-2010 07:36
Moving Part Arm penguain Rules/Strategy 2 03-02-2008 11:10
pic: Full Scale Prototype Ringer Arm 2007 lynca Extra Discussion 5 20-01-2007 00:25
Arm mounting on moving tracks? welderman5000 Technical Discussion 4 10-01-2007 00:16
pic: full frame arm CD47-Bot Extra Discussion 4 16-02-2004 19:14
