Go to Post Because when you build the people and the team, building the robot comes much easier. - Koko Ed [more]
Unread 27-03-2010, 02:04
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Repair of 2007 Victor 884
Ok... I give up. What is the secret of opening up a 2007 Victor 884 that has no screws on the bottom or top?
Seems like Innovation First doesn't want to make it easy to get to the circuitry like we could with the 2004 884.
Unread 27-03-2010, 02:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Repair of 2007 Victor 884
Push and pry. It breaks the case when you do it, so you'd have to reassemble with glue. Also, the transistors used in it are not a real easy to find item if I recall.
Unread 29-03-2010, 11:09
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Chris,
A putty knife or some other long object inserted around the base will open the case. It is just friction fit. Be patient and don't try to pry open one side too far before moving on.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 29-03-2010, 19:34
AKA: Chris
FRC #0599 (Robodox)
Al,
Friction is a kind word... more like #%^$*& stuck for good. So I had to push and pry and of course several of the little black pins snapped off like sanddrag said but its open. I think Innovation First was out of their minds to save a little on screws. Now I begin the search for some 3103 Fets.
Unread 30-03-2010, 18:58
DonRotolo's Avatar
Back to humble
FRC #0832
Digi-Key sells them. There is an alternative number IIRC, try this post
Unread 30-03-2010, 20:36
Gdeaver Gdeaver is online now
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
I have a 2007 victor 884 and it used Infineon IPP042N03L FETS available from digikey.
Unread 30-03-2010, 23:33
Unsung FIRST Hero
Rookie Year: 1996
Chris,
Maybe the FETs over temped and melted some of the case together. I have opened several over the years and didn't have that much trouble. Sometimes it is helpful to show a team just how much crud can build up inside on the robot.
Al
WB9UVJ
www.wildstang.org
Unread 31-03-2010, 02:34
AKA: Chris
FRC #0599 (Robodox)
I finally got around to looking at these and they indeed are Marked 2n03L13 which translates to a Infineon SPI42N03S2L-13 based upon this spec:
http://www.infineon.com/dgdl/SPP_B_4...12b4271adf3b95
So we only have 42 amps instead of the 60+ from the IRL 3103.
This shows up as an obsolete item on DigiKey:
http://search.digikey.com/scripts/Dk...SPI42N03S2L-13
Also noticed the board is marked 883 Rev F.
Anyone come across a ckt for an 883/884 yet or are we stuck with generic ckts?
Unread 31-03-2010, 06:38
Unsung FIRST Hero
Rookie Year: 1996
They are wired in parallel for 126 amps each leg. Slightly higher series resistance.
Al
WB9UVJ
www.wildstang.org
Unread 31-03-2010, 07:57
FRC #1640
I don't have time to do it this morning but I believe the IPP042N03L G matches ok with the others. You can check the data sheet for the match ups. I believe I used these and they seem to work fine.
Unread 31-03-2010, 13:10
AKA: Chris
FRC #0599 (Robodox)
Ok..lets compare (Vdss,Rds_on,Id)
IRL3103 30v,12mho,64 amp 2004 Victor
2n03L13 30v,12.9 mho,42 amp 2007 Victor
042N03L 30v,4.2 mho,70 amp Gdeaver replacement
So the 042N03L looks more capable and would make a nice substitute. But this raises a question: What constitutes a First legal 884?
AllElectronics is a few blocks from me and has a stock MTP75N03HDL
http://www.datasheetcatalog.org/data...75N03HDL-D.PDF
MTP75N03HDL 25v,9 mho, 75 amp AllElectronic sub
This might work too, but probably shouldn't be legal for competition right?
Unread 31-03-2010, 14:40
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I think per <R60> it wasn't legal as soon as the case was opened.
Victor 884 Issues BHS Bucs Electrical 3 01-02-2008 15:10
Victor 884 Devo1098 Electrical 6 29-06-2007 07:51
Victor 884 problem Gal Longin Control System 11 26-01-2005 00:47
Victor 884 Kevin Ray General Forum 25 28-01-2003 15:02
Victor 884 Gary Bonner Technical Discussion 4 14-01-2002 08:10
