Go to Post Everyone here inspires each other and helps them out. That's why FIRST is amazing. - tiffany34990 [more]
Unread 27-03-2010, 15:08
Ted3299 Ted3299 is offline
Team 3299 Programmer
FRC #3299 (Warehouse Crew)
Team Role: Driver
Rookie Year: 2010
Ted3299 is an unknown quantity at this point
Problem with watchdog and movement
Hey there, this is my first time using this site, its a little long, and I'm not really working on the programing so please bear with me.
My problem is that we have been using our robot the past couple of days perfectly. We attached a mechanism to lift ourself's and it worked great, the only problem being it was too slow so we decided to change the values on the system to pump a little more votage to those motors to get it to run faster. In the end, all we did on LabView was change a couple of values to get more voltage to it.
We removed the lifter to work on it a little more to make sure it will work proficiently. After removing it, we uploaded the code to the C-RIO and called it a night, without testing it agian.
Problem-
Today, we booted up the robot, got it all set to go. First thing I noticed when I pressed enable was that it said "Watchdog Not Fed" and then quickly switched to "Teleoporated Enabled". I then pressed forward on the joysticks. The robot moved approximately 6 in., stoped and lost communication.
I tried it agian after I got the ok on everything and tried it agian, same result. We then rebooted the router, computer, robot, robot/computer to no result.
After a few of the reboots, I started noticing the communication going in and out every half second or so. and the only error message I recieve on the Diagnostics Tab is "Watchdog expiration: System 1,3,4,5,6,7,8 (commas meaning different messages) User 1,2"
Possible help for solution-
UPDATED- I think I've narrowed it down to the wiring getting jolted when it hits something to hard or starts too fast.
(MOVE TOPIC PLEASE)
Unread 27-03-2010, 16:14
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Problem with watchdog and movement
What's your battery voltage?
Unread 27-03-2010, 17:20
NullEntity's Avatar
NullEntity NullEntity is offline
AKA: Bryce
FRC #0093 (N.E.W. Apple Corps Robotics)
Team Role: Scout
NullEntity is an unknown quantity at this point
I remember having to reboot the cRIO to fix this problem once.
FRC Team 93 Alumni
Watchdog Problem kgzak NI LabVIEW 10 21-02-2010 20:37
Problem with System Watchdog JSonntag NI LabVIEW 14 20-02-2010 11:31
Watchdog Problem daniel_3158 Programming 3 12-02-2010 15:22
example project Autonomous mode Watchdog problem qpang NI LabVIEW 0 08-02-2010 16:17
Vex SquareBot- movement programming problem Nathan VEX 2 05-11-2006 17:19
