Go to Post Brandon Martus, making CD readers' lives easier since May 2001/Fall 98 - Beth Sweet [more]
Unread 28-03-2010, 11:33
Steve Compton Steve Compton is offline
Project Manager, Mentor
FRC #1391
Steve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to behold
powr dist. board/cRIO puzzle - please advise!
In our second quarterfinal match yesterday, our robot went over the bump and upon hitting the ground on opposite side, the cRIO cut out and we were dead on the field. Back to the pit, tethered up and could not recreate the problem. Out to the field and the first bump to the robot and it went out again, then rebooted after time, the cut out again.
Troubleshooting afterward (haing won the first match, we lost the second two), we found that if we pulled one specific fuse to one of our window motors, the cRIO problem was gone - we could smack the robot into walls, shove it, bounce it up and down, etc and no problem. We put the fuse back in... and simply picking one end of the robot up a couple inches and dropping it caused the failure to occur.
I'd appreciate your good minds on this one, and thanks!
cRIO Imaging Tool HELP PLEASE!!! furiousgeorge FRC Control System 2 08-02-2009 22:44
**IMPORTANT GEAR TOOTH SENSOR BOARD UPDATE** STICKY PLEASE www.divsys.com General Forum 16 06-02-2008 16:54
need help with power dist block & maxi bkr steve d Electrical 4 07-02-2007 18:07
