Go to Post But you are right about one thing, it is downright un-American. The Triplets are Canadian. - rourke [more]
Unread 28-03-2010, 14:07
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Re: WET610N DISQUALIFICATION at regional event!!
Originally Posted by RoyerAJ View Post
I ... dropped us in rankings and any chance we had of making it to finals. ...
Let's think twice about this. A shortage of seeding points would get in the way of becoming an Alliance Captain; but it should not have interfered with a good team_plus_robot being drafted.
High seeding points are certainly not the only way to join a strong elimination round alliance.
Blake
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 28-03-2010, 15:26
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
I am on team 2004 The Thunderducks, we were the only team at the OKC regional to use the WET610N for the entire competition. Initially we were actually disqualified for using illegal hardware!!!!!!!!
I'm not sure what you mean by "disqualified". If you're referring to <T10> and <T11>, no you weren't disqualified - or if you were, the score were corrected afterward. Take a look at the match scores and seeding points. If you add the seeding points from each match, you'll see that the total is 70, which is what the official rankings page says.
Had you been DQed in the first two, your seeding score would have been 62, and you would have been ranked 46th.
I assume that you actually mean that your robot simply didn't work because of communication problems (which is what it looks like from the match video). In short, that's unfortunate and painful, but it happens. You weren't the only team to have a dead robot because of field-related problems.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
WET610N Reset Button thexman Electrical 1 12-03-2010 06:06
WET610N configuration Yuan Xue Lim FRC Control System 0 22-01-2010 00:37
Newton Final 2: Reason for disqualification ham90mack Championship Event 17 10-03-2008 23:38
[OCCRA]: VEX disqualification Mike Martus OCCRA Q&A 0 19-09-2007 21:41
VCU DISQUALIFICATION! Tomasz Bania Regional Competitions 36 09-03-2006 08:06
