Spontaneous motor skipping?
We appear to be having an odd problem with our drive motors.
Following an odd voltage drop resulting in the loss of control of our bot in the quarter-finals at WAT, we had discovered that one CIM and its accompanying Jag were noticeably hotter than the others. After removing the electronics and offending gearbox, getting home and testing them on benchtop, we've noticed two things: 1) after removing our CIMs from the gearbox the one that was overheating is also making an odd clicking and is noticeably louder than the other. [Resolved] 2) that our CIMs "jump" and will randomly stop for a random duration between 1/4 and 1/2 a second. When this happens, all the motors jump simultaneously, and the lights on all the Jaguars flash yellow/amber for a brief period while the motors stall. We HAVE tried changing the DSC and 9403 cRIO modules, to no avail. Last edited by Damaku250 : 29-03-2010 at 17:27. |
Re: Spontaneous motor skipping?
Craig,
Sounds like you have a shorted winding in the CIM motor. No way to fix that, just replace. |
duly noted, but would this cause the second part of the problem?
Yes, you are drawing down the 12 volt supply which draws down the DSC power that in turn plays havoc with the PWM outputs.
We have now removed the borked motor and are testing with the good one. We are still experiencing "skipping". What could be causing this?
Craig,
Is the robot signal light also blinking out at the same time? |
No, the RSL is staying on and we do not appear to be experiencing power interruptions on any other components on the board.
You are using the same Jaguar? Suspect that as well.
Are any of the lights on the PD winking out at the same time? |
The lights on the PDB are staying solid. We have tried 5 different versions of code, all of which are not affecting the problem. |
#10
Craig,
Is this a new problem? Have you had this all season or just recently? It is possible that you have the dreaded watchdog issue. Someone posted last night that there is an issue with Classmate power settings as well. I believe the Classmate issue occurs at 15-20 second intervals while the watchdog is something longer. |
#11
It is definitely not a 15-20 second cycle, we've had the CIM running for up to 1:30 before it skips before. It may be a Watchdog issue - I'll go run another test and keep an eye out for the Watchdog issue.
This is, as far as we know, a completely new issue however. We hadn't noticed this motor skipping problem for all of build season or all of the practice and seeding matches at Waterloo. |
#12
Watch the little screen on the lower left of the
driver station display. Do you see a momentary "watchdog not fed" message correlated with the motor glitches? If you see it, you have the dreaded watchdog issue Al mentions. Eugene |
| [Vex] Spontaneous channel switching/dying | Joe G. | VEX | 2 | 15-04-2009 16:17 |
| Motor speed sensing with the Jaguar motor controller? | mminutto | FRC Control System | 5 | 13-01-2009 18:13 |
| White Paper Discuss: Approx. Motor Spec for Taigene Motor | Joe Johnson | Motors | 2 | 22-01-2005 16:36 |
| External metal jacket on the Drill motor and FP motor, WHY? | archiver | 2001 | 3 | 24-06-2002 04:22 |
| External metal jacket on the Drill motor and FP motor, WHY? | Dennis Hughes | Technical Discussion | 1 | 04-06-2001 11:59 |
