Go to Post Finally I wish everyone here on ChiefDelphi good luck and more importantly a fun build season. - mechanicalbrain [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 29-03-2010, 17:25
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Robot Communications at the Championship
I'm sure FIRST has got this covered, I'm just interested so I thought maybe someone could shed some light on this subject:
with 4 fields running simultaneously fairly close to each other, is it necessary to set up the communication in a special way to avoid communication problems? if so what do you imagine (or know) this configuration to be?
would a WiFi expert look at this setup (24 robots running simultaneously on 24 different networks) and see a potential problem, or would he shrug it off as a non-issue?
I'd appreciate to learn more about the advantages and limitations of the 802.11n protocol and the configuration used.
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Robot Communications dies as Motor speed increase Michael Fadaie NI LabVIEW 4 19-02-2010 00:55
No Robot Communications alex42 FRC Control System 4 10-02-2010 20:42
No Robot Communications Team2191 FRC Control System 1 22-01-2010 20:12
[FVC]: Transporting your robot to the Championship nonother FIRST Tech Challenge 14 31-03-2007 01:40
Communications via the Programming Port Larry Barello Technical Discussion 9 10-06-2003 23:33
