Re: Programmers: I Have A Challenge For You
15 seconds isn't enough to take advantage of full-field awareness.
It's only enough time to do something and hope it works. (For example, if you fire a ball into the goals from mid- or far- field, you don't have enough time to go over there and make sure it actually went in.) |
http://robotics.nasa.gov/first/2004/kickoff.htm It used $10-$15 dollars worth of parts plus some custom code that's still available here: http://kevin.org/frc/2004/ -Kevin |
1114 didn't prove him dead wrong this year. 1114's ranking at any regional would definitely not have been different if they stayed still during autonomous. The robot was averaging 1-2 balls scored per autonomous mode. Our robot averaged 1 ball per autonomous mode, and despite being a much weaker team, the one match where that one score mattered was better known as the match where we got disqualified.
2004, several teams hung in autonomous and then controlled the bar, they swung the match score up to 150 points (+50 for their hang -100 for their opponents not being able to hang). I guess that isn't serious. 2006, winning auton was a huge benefit. I saw many matches decided by auton alone. 2008, 1114, do I need to say more? Ok, 217. There you go. Auton could decide the match. 2009, on Einstein the final match autons consisted of loading up the bots to go dump a load into their opponents, not as important but it added many balls to the arsenal of the dumpers (or 217's shooter). 2010, 469 shows how useful a good auton can be. If they get set in auton you are pretty much down 4 points at the start of the match (They score 2 balls and then recycle them as soon as people start moving). I would say that 15 seconds is plenty of time to do something important. |
All who are trying this: I have a book for you. http://www.amazon.com/Introduction-A.../dp/026219502X
The TOC: Code:
Contents
Acknowledgments xi
Preface xiii
1 Introduction 1
1.1 Introduction 1
1.2 An Overview of the Book 10
2 Locomotion 13
2.1 Introduction 13
2.1.1 Key issues for locomotion 16
2.2 Legged Mobile Robots 17
2.2.1 Leg configurations and stability 18
2.2.2 Examples of legged robot locomotion 21
2.3 Wheeled Mobile Robots 30
2.3.1 Wheeled locomotion: the design space 31
2.3.2 Wheeled locomotion: case studies 38
3 Mobile Robot Kinematics 47
3.1 Introduction 47
3.2 Kinematic Models and Constraints 48
3.2.1 Representing robot position 48
3.2.2 Forward kinematic models 51
3.2.3 Wheel kinematic constraints 53
3.2.4 Robot kinematic constraints 61
3.2.5 Examples: robot kinematic models and constraints 63
3.3 Mobile Robot Maneuverability 67
3.3.1 Degree of mobility 67
3.3.2 Degree of steerability 71
3.3.3 Robot maneuverability 72
viii Contents
3.4 Mobile Robot Workspace 74
3.4.1 Degrees of freedom 74
3.4.2 Holonomic robots 75
3.4.3 Path and trajectory considerations 77
3.5 Beyond Basic Kinematics 80
3.6 Motion Control (Kinematic Control) 81
3.6.1 Open loop control (trajectory-following) 81
3.6.2 Feedback control 82
4 Perception 89
4.1 Sensors for Mobile Robots 89
4.1.1 Sensor classification 89
4.1.2 Characterizing sensor performance 92
4.1.3 Wheel/motor sensors 97
4.1.4 Heading sensors 98
4.1.5 Ground-based beacons 101
4.1.6 Active ranging 104
4.1.7 Motion/speed sensors 115
4.1.8 Vision-based sensors 117
4.2 Representing Uncertainty 145
4.2.1 Statistical representation 145
4.2.2 Error propagation: combining uncertain measurements 149
4.3 Feature Extraction 151
4.3.1 Feature extraction based on range data (laser, ultrasonic, vision-based
ranging) 154
4.3.2 Visual appearance based feature extraction 163
5 Mobile Robot Localization 181
5.1 Introduction 181
5.2 The Challenge of Localization: Noise and Aliasing 182
5.2.1 Sensor noise 183
5.2.2 Sensor aliasing 184
5.2.3 Effector noise 185
5.2.4 An error model for odometric position estimation 186
5.3 To Localize or Not to Localize: Localization-Based Navigation versus
Programmed Solutions 191
5.4 Belief Representation 194
5.4.1 Single-hypothesis belief 194
5.4.2 Multiple-hypothesis belief 196
Contents ix
5.5 Map Representation 200
5.5.1 Continuous representations 200
5.5.2 Decomposition strategies 203
5.5.3 State of the art: current challenges in map representation 210
5.6 Probabilistic Map-Based Localization 212
5.6.1 Introduction 212
5.6.2 Markov localization 214
5.6.3 Kalman filter localization 227
5.7 Other Examples of Localization Systems 244
5.7.1 Landmark-based navigation 245
5.7.2 Globally unique localization 246
5.7.3 Positioning beacon systems 248
5.7.4 Route-based localization 249
5.8 Autonomous Map Building 250
5.8.1 The stochastic map technique 250
5.8.2 Other mapping techniques 253
6 Planning and Navigation 257
6.1 Introduction 257
6.2 Competences for Navigation: Planning and Reacting 258
6.2.1 Path planning 259
6.2.2 Obstacle avoidance 272
6.3 Navigation Architectures 291
6.3.1 Modularity for code reuse and sharing 291
6.3.2 Control localization 291
6.3.3 Techniques for decomposition 292
6.3.4 Case studies: tiered robot architectures 298
Bibliography 305
Books 305
Papers 306
Referenced Webpages 314
Interesting Internet Links to Mobile Robots 314
Index
As you can see, it covers everything from the Perception to Logic and even drive systems Last edited by davidthefat : 11-04-2010 at 22:51. |
2003 purpose, to knock your boxes to your side of field. Auto gave you a good position and start against your opponents. 2004 Purpose to knock down the balls early in game. Gave you a small advantage. But mostly if you moved during auto you go noticed. It was a fun one to do and watch. 2005 It was the tetra year and idea was to put the tetra in place. It was a bust. Almost no one could do much with it, too hard. 2006 Aim high place balls in corner or middle target. It was 1902's rookie year and we had a simple auto mode that consistently put 10 balls in corner and gave bonus points. Because of that we were 9-0 in Houston. 2007 Rack and Roll, place tube on rack. Many said it did not help. I calculated it made the difference in winning or losing several matches. 2008 Race around track and knock down balls. This was the most fun and challenging auto mode. Could make huge difference. 2009 Auto was hard and mostly in my opinion did not make a big difference unless you didn't move and you got nailed for not moving. Bottom line auto modes are fun and most years make a difference. Longer than 15 seconds and it becomes boring because most teams do not even move during that time. I think auto mode is important for a team because you stand out during that the 15 seconds awhile so many others just sit there. |
#10
The thing I notice about all of those is that autonomous is always playing an assistive role to teleop. I wonder if that could be reversed?
#11
I love the sound of this, but I can almost guarantee my team won't.
#12
Once you create a machine that can score a ring (or some other useful function) during the autonomous period, you use that capability like a macro to automate scoring during the entire match. A good autonomous scorer, becomes a predictable/reliable tool for the drive team to use throughout teleop. It multiplies their effectiveness and frees them to think about higher level concerns, instead of the minutiae of the actions a machine can carry out on their behalf. How about starting with this general mindset and then pushing it as far as we are able? Blake |
#14
Understand this. This is a beatable robot. All robots can be defeated with strategy. - Alexander McGee
Please see team 71 in 2002: http://www.youtube.com/watch?v=h4slvnvPHW8 |
#15
Many people said the same thing about 469 on einstein this year - that they were a lock with 1114. It requires a clear understanding of the game and a good grasp of strategy, but any robot is beatable. |
| For those of you that have seen a field | goldenglove002 | General Forum | 1 | 13-02-2010 21:56 |
| SE MI Teams - I have pool noodles for you! | kmcclary | General Forum | 1 | 05-02-2010 20:29 |
| Any Programmers Have The Same Feeling As Me? | davidthefat | Programming | 23 | 16-01-2010 22:07 |
| What have you given up for FIRST? | Michael Leicht | General Forum | 138 | 11-01-2008 10:47 |
