Go to Post make sure to make it look really cool, it makes it easier for teams to remember you, which comes in handy for alliance selections ;) - Holtzman [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 30-03-2010, 00:32
akeisic's Avatar
akeisic akeisic is offline
Systems and Strategy Mentor
AKA: Andrew Keisic
FRC #4201 (The Vitruvian Bots)
Team Role: Leadership
Rookie Year: 1999
akeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to all
4 Match Finals & Biggest Tie Match
While 3 match elimination rounds aren't uncommon, they are certainly not the norm. And a 4 match elimination round almost never happen - let alone a 4 match final! Yet, that's exactly what happened in LA this past weekend...(12-12, 10-14, 10-8, 3-9)
The vids are amazing...http://www.thebluealliance.net/tbatv/event/2010ca
Match 1: http://www.youtube.com/watch?v=jPST3RWJU5k
Match 2: http://www.youtube.com/watch?v=TYQwMiBeuho
Match 3: http://www.youtube.com/watch?v=EaF85KzeD0w
It appears FIRST doesn't even have provisions for such an occurrence. http://www2.usfirst.org/2010comp/eve...chresults.html Note the match order as well...it's all messed up. Going by their order, it should have never gone to a third match. The BlueAlliance got it mostly right: http://www.thebluealliance.net/tbatv/event/2010ca and I know they're working to fix it.
I was wondering if anyone else knew of any other 4 match elimination rounds - in any year.
Furthermore, I think we might have set a highest tie score in the country for 2010 at 12-12, but wanted to see if anyone else had seen anything higher.
Mentor: FRC 4201 - The Vitruvian Bots
Awards with FRC 294 - Beach Cities Robotics
2014: LA FRC Champions
2012: LA FRC Finalists
2011: San Diego FRC Finalists
2010: San Diego FTC Finalists, San Diego FRC Champions, LA FRC Finalist, FRC World Champions
2009: LA FRC Finalist
2008: San Diego FRC Champions, LA FRC Finalist, LA FTC Champions, LA VCR Champions,
2007: San Diego FRC Finalist, San Diego FTC Champions, FTC World Champions
Unread 30-03-2010, 00:36
JoshD's Avatar
JoshD JoshD is offline
FRC #0975 (Synergy)
JoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to behold
Send a message via AIM to JoshD Send a message via MSN to JoshD
Re: 4 Match Finals & Biggest Tie Match
I know this year one of the semifinal rounds in Virginia had 5 or 6 rounds because the two alliances tied so many times. It was nuts, not to mention it took a while!
Unread 30-03-2010, 01:31
Sunbun's Avatar
Sunbun Sunbun is offline
AKA: Sunny
FRC #1197 (TorBots)
Rookie Year: 2007
Sunbun is a glorious beacon of lightSunbun is a glorious beacon of lightSunbun is a glorious beacon of lightSunbun is a glorious beacon of lightSunbun is a glorious beacon of light
I think that the FMS is only capable of three matches per set of two alliances. It can't really "create" a 4th match, so when there's a tie someone has to manually go and "replay" one of the matches that tied.
This is why Final 4 is actually "Final 1." You can see this happening around TBA when the winners of Final 3 aren't actually the regional winners.
Unread 30-03-2010, 01:57
Peter Johnson Peter Johnson is offline
WPILib Developer
FRC #0294 (Beach Cities Robotics)
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Yeah, I think you're right. You can see that pretty clearly on the frcfms Twitter feed for the finals in question: http://twitter.com/search?q=%23FRCCA (E MC 19 repeats).
Unread 30-03-2010, 03:08
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Rookie Year: 2007
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
The quarterfinals at Palmetto had a 4 matcher, and a 5 matcher(IIRC). It's pretty spectacular, especially being a drive coach during a 4 match quarterfinal where you lose the first game, and then luckily tie the second even though your entire alliance is dead in the water. 2815 played a spectacular match for #3 to make it 1-1-1 and then finally every bot on the field was up and running for the 4th match, which we won 4-2.
TBA doesn't even have our 1-1 tie match up for the quarters
Unread 30-03-2010, 06:52
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
BAE had a 4 match finals
Unread 30-03-2010, 07:16
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
The WPI regional had a 5 and 6 rounds in the elimination matches
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Unread 30-03-2010, 07:27
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
Rookie Year: 2007
whatabouteve is an unknown quantity at this point
Here in Michigan we've go through that 2 times.
At the Kettering District, we tied 2 times and lost 2 times.
At the Wayne State District, we Tied 1 time, 1 once, lost once, and were DQ'd the last match even though we had a higher score.
Unread 30-03-2010, 08:01
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
At Palmetto, one of the semi-final rounds lasted FOREVER. They must've tied at least 3-4 times. Or, I think it was quarterfinals. Regardless, it gave everyone else a good one hour break.
1648: 2013-2014
5283: 2015
Unread 30-03-2010, 09:29
mayhemscout1519's Avatar
mayhemscout1519 mayhemscout1519 is offline
2010 GSR Champs
AKA: Ben Streeter
FRC #1519 (Mechanical Mayhem)
Team Role: Mechanical
mayhemscout1519 will become famous soon enough
As mentioned above, BAE had a 4-match finals. The alliances were the #1 seeded 1922, 78, and 134 red alliance against the #2 seed 1058, 1519, and 1073 blue alliance. The first match went decisively to blue (11-1) as 1922's robot did not move for the entire match, starting from the red far zone, allowing blue's offensive robots, 1073 and 1058, to score undefended in their near zone. In the second match, all robots were working according to plan and it was a nail-biter ending in an 8-8 tie. However, during the second match, 1519's robot suffered damage due to aggressive pushing matches with 134 who was countering 1519's far zone defense so that 134's partners, 78, could score. As a result of the damage to 1519's robot, the #2 seed alliance took their 6-minute time-out to make the necessary repairs. Unfortunately, 1519's robot was not 100% ready to go - our kicker was still not functioning correctly. As a result, we did not clear the red far zone and 1922's alliance took it in another nail-biter, 9-7. This forced a fourth match.. During the short down time between the third and fourth match, 1519 was able to get their robot working again and it showed in the finale as we played D on 134 and 78, while 1058 and 1073 did what they had been doing through the finals - scoring lots of goals from the mid-field (1058) and the home zone (1073)!
With the low scores this year (due to the way the scoring system is set up: few playing elements and a limited number of ways to score, with no multipliers or similar things as in previous years), there have been many more ties, meaning lots of long elimination contests! Personally, I really like the fact that there have been lots of elimination ties - I think it adds to the excitement of the game for the spectator (even if it causes teams to stress a little more!).
Unread 30-03-2010, 11:05
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
4 match eliminations rounds are not "common," but certainly not an incredibly rare event. 5 match eliminations are more rare, but are much more common this year than in previous (happened in Virginia, Palmetto, WPI, and possibly elsewhere).
Unread 30-03-2010, 11:08
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
It seems that Breakaway is more prone to ties than any game in recent memory, which may be the reason for the rise in 4 and 5 match eliminations.
That being said, a 12-12 tie is quite impressive, though we can't really compare it to scores from previous years. (I guess it could be, but I don't feel like doing the math...)
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 30-03-2010, 11:11
carolynn4848's Avatar
carolynn4848 carolynn4848 is offline
a.k.a. Coraline
FRC #1735 (Green Reapers)
Team Role: Operator
Rookie Year: 2007
carolynn4848 is a glorious beacon of lightcarolynn4848 is a glorious beacon of lightcarolynn4848 is a glorious beacon of lightcarolynn4848 is a glorious beacon of lightcarolynn4848 is a glorious beacon of light
Send a message via AIM to carolynn4848 Send a message via Yahoo to carolynn4848
At the WPI regional, one of the quarter final matches had 5 rounds, and another one had 6.
I think I have an addiction. To FIRST.
I am Coraline! Hear me roar!!
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
WPI had a 5 match round AND a 6 match round.
  #15   Spotlight this post!
Unread 30-03-2010, 08:21
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Which is exactly in compliance with the rules in Section 9.
Originally Posted by 9.4.3
In order to allow equal time between matches for all ALLIANCES, the order of play will be:
QF1-1, QF2-1, QF3-1, QF4-1,
Then QF1-2, QF2-2, QF3-2, QF4-2,
Then QF1-3*, QF2-3*, QF3-3*, QF4-3*
Then any QF replays due to ties*
Then SF1-1, SF2-1, SF1-2, SF2-2, SF1-3*, SF2-3*
Then any SF replays due to ties*
Then F-1, F-2, F-3*
Then any F replays due to ties*
(* - if required)
(Note "replays due to ties")
(since 2004)
pic: 1024 just before first finals match at Midwest Regional Qbranch Extra Discussion 3 14-04-2008 22:20
pic: FVC finals match doukjin Extra Discussion 2 19-03-2006 20:16
Anyone have the finals match results for AZ 2004/2005? jpsaul7usa Regional Competitions 0 26-07-2005 15:36
pic: The First Finals Match Scores dubious elise Extra Discussion 6 24-03-2005 11:47
pic: quater finals 1 match 1 CD47-Bot Extra Discussion 1 06-03-2004 22:00
