Go to Post There's a fine line between idolizing someone and stalking! - Jay H 237 [more]
Unread 31-03-2010, 09:38
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: 30a breaker for 40a spot on pdb
Thanks for all the great info. Our main tripped in the last match at Milwaukee with about a minute left. We were kind of angled into the tunnel trying to get past another robot that was blocking. The main tripped. There is no way anything mechanical tripped it, it is to well protected from that. What is confusing is that I don't think we were pulling any harder than we had at many other times that day. At the time we had a ball on our vacuum and it was running. Not sure what it draws with a ball on it but the 2 FP motors pull about 30a when running free. So, that in conjunction with stalled cims is what probably tripped the main??
Bruce
Unread 31-03-2010, 10:14
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Literally thousands of teams have been using 4 CIM drivetrains with 40A breakers on each CIM for years. I doubt this is your issue.
Personally, my team has never tripped the 120A main breaker. We've had the 40A's in a 4CIM treaded tank drive stalled and popping, and never popping the main. I would look to something mechanical, or possibly a faulty main breaker.
Unread 31-03-2010, 15:44
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Bruce,
There was another team in Milwaukee that also tripped the main breaker. They thought is was protected as well but what we found was a small crack in the case. The slight misalignment was enough to cause the breaker to let go. There is another known issue with the breaker. A few over the years have shown up with manufacturing defect. A simple tap on the red button is sufficient to trip the breaker. The test is to tap with your finger and see if it fails. Over the last four years I think I have seen a total of less than ten.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 31-03-2010, 10:19
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
There was a team at the Los Angeles regional who's circuit breaker would trip when they had a hard impact. After repositioning it and shock mounting it, it still occurred. They were able to reproduce the problem on the practice field by running it into the wall or over a bump hard. They replaced it with a new breaker and it didn't happen again.
What was the position of the black lever on the circuit breaker when you lost power?
Unread 31-03-2010, 12:05
Bruceb's Avatar
it was in the tripped....lever sticking out position. Just like it is when you push the red button.
Also for EricH. You say we have Wednesday night to get ready for competition but the rules I have read say uncrating only on Wednesday night. Doesn't even look like they want you setting up the pit or working on the robot at all. What am I missing?
Bruce
Unread 31-03-2010, 12:16
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
The main breaker will run at 2x its rated current for at least ten and up to 40 seconds. That's 240 amps. If it tripped on the field, inspect your big wires and crimps (between the breaker and fuse panel) for shorts, and consider replacing the breaker itself. The big breaker is there to keep stuff from catching fire, it shouldn't trip in regular operation.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 31-03-2010, 12:53
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Bruce
The FIRST email about the Championship is what you're missing.
They've been monkeying with the Championship schedule and similar things to allow the following on Wednesday night:
--Uncrating
--Pit setup
--Inspection
--work on robots (after all, you want to fix what you found out was illegal at inspection, right?)
They just haven't updated any Manual sections that cover this sort of thing--but all the info comes from Bill Miller and/or the FRC staff, so it's legit.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 31-03-2010, 14:44
Bruceb's Avatar
Are they allowing more then 5 people in to do all that stuff Wednesday night?
Bruce
Unread 31-03-2010, 16:33
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Bruce
Nope. 5 is the max, unless you can steal some from another team that's already in there. (All the other teams are probably trying to do the same thing...)
Past teams:
A Tip for the PDB Pavan Dave Electrical 4 06-01-2008 22:20
CIM motor on 30A jason701802 Motors 4 05-02-2007 20:23
What guage wire do you use for 40A circuits SuperBK Electrical 6 21-01-2007 14:58
Bad 40A Breaker Richard Wallace Electrical 3 18-02-2003 21:42
Our 20A and 30A and 40A breakers . . . Frank(Aflak) Technical Discussion 8 01-02-2003 08:36
