Go to Post ... it's us against all the bad-grammar-usin', "ya know"-slingin', graciously excepting, "congradulations"-totin', "nu kU ler"-spoutin' linguistic Luddites out there. We'll see who wins! :D - dlavery [more]
Unread 30-03-2010, 18:19
scawsome's Avatar
scawsome scawsome is offline
FRC #0230
Team Role: Driver
scawsome will become famous soon enoughscawsome will become famous soon enough
pic: The lights! The lights!
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
Re: pic: The lights! The lights!
Awesome! Aesthetically pleasing and functional. Good luck.
Unread 30-03-2010, 19:03
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Rookie Year: 2007
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Nice!
I like the functionality that was attached to the lights so they serve more than one purpose.
Out of curiosity, where'd ya'll get them and/or hook them up?
-Tanner
Unread 30-03-2010, 22:00
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
-Tanner
They look similar to the ones we used. http://www.dealextreme.com/details.dx/sku.14965
Eric Haskins KC9JVH
Unread 30-03-2010, 23:08
Rick Vogl's Avatar
Rick Vogl Rick Vogl is offline
FRC #0230 (Gaelhawks)
Rookie Year: 1998
Rick Vogl is on a distinguished road
The lights were purchased from a local company http://www.lighthouseww.com/index.ph...index&cPath=81. A bit expensive but extremely bright. If you buy from them mention our team it might increase my discount.
Unread 31-03-2010, 07:09
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
Do you have 2 strips of lights there or just 1 strip of the color changing ones? Also curious how you hooked them up to allow you to change color as well as flash them with the pneumatics? I'm assuming that there current draw was too great to just put right off one of the break out boards.
Unread 31-03-2010, 13:44
Rick Vogl's Avatar
Rookie Year: 1998
There are two strips of lights, red and blue. Each strip is driven by a spike relay module. We have a Hobbs digital pressure switch set at 60 PSI on the pneumatics. The robot will flash the lights until that pressure is read by turning the relay on and off. The pressure switch was in the 1999 or 2000 kit of parts. Most of our robot is made of recycled parts including the lights that we used last year.
Unread 31-03-2010, 15:42
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Each on a Spike? You do know you can use one spike to do that - Set it to "OFF" and both are off, set it to "FORWARD" and one is on, set it to "REVERSE" and the other is on, or set it to "ON" and both are on. Connect the + inputs of each light to the M+ or M- on the Spike and run the - to the GND on the Spike (input side) or to any spare black connection on the PD board.
We have six 12" lights on our robot, connected to 3 Spike channels (2 spikes), in Red, Green, and Blue. No RGB color, just Red, Green, or Blue (or more than one). We use Blue to indicate ball in and Green to indicate High Gear (much easier for the coach to yell at the driver for running around in LOW). When the robot hangs from the vertical pole, they flash in sequence as soon as it is above the platform.
Kettering Motorsports
Unread 01-04-2010, 17:34
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
That arrangement doesn't sound legal to me, but I need to re-read the rules carefully to be sure.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Are Lights Allowed on the Robot?? team 2191 Electrical 5 14-02-2008 18:00
The chasing-lights RC error Eldarion Control System 7 25-01-2006 18:23
One of the RC lights is out devicenull Control System 1 13-02-2005 22:41
Lights on the Control Panel Han Tzu Electrical 5 08-02-2005 13:30
Rotating Lights in the stands? psychoCHIPMUNKK Rules/Strategy 4 19-02-2004 23:47
