Go to Post FIRST truly isnt about building robots, but allowing yourself to reach higher and farther than you ever could. - Brandon Holley [more]
Unread 31-03-2010, 18:50
sv2198 sv2198 is offline
FRC #0088 (TJ Squared)
Team Role: Student
Rookie Year: 2007
sv2198 is on a distinguished road
Re: Scoring error at Boston.
After watching that autonomous closely several times I agree that only one ball was and should be scored. It's hard to tell if it was an automatic penalty, or if it was a field error.
Unread 31-03-2010, 18:27
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Originally Posted by sv2198 View Post
During our Semi-final match, there was a scoring error that occured, were our alliance had 4 total point subtracted from the score. 1 in autonomous, and 3 during tele-operated. The point that was scored in autonomous was not counted, and the other three were subtracted when we scored one, the score went down two. I've viewed this match several times, just to make sure i'm not seeing things. We ended up winning the match anyways, but its a little concerning that there is some scoring issues. I was wondering if anyone else have ran into this problem.
O and you can view the match on the blue alliance right here. http://www.thebluealliance.net/tbatv/match/2010ma_sf1m1
Reviewing the original video several more times, I'm not sure I agree that 2 balls were scored by blue in autonomous.
During the autonomous period, red clears one ball, blue kicks 2 balls from midfield, scoring with one of them. There is also a shot from the blue offensive robot which looks like it is being scored since the ball disappears from shot very close to the goal mouth, but as the cameral zooms back there is a ball rolling along the alliance wall.
At the end of autonomous, 1 ball was cleared from defense by red, 2 were moved forward from midfield by blue, and there are 4 balls left in the zone, therefore only 1 was scored by blue.
That still leaves the reduction in points during the match. This could be a field fault as discussed above but can we completely rule out a DOGMA penalty?
Error... LARGE error with classmate Brett Elflord General Forum 4 18-02-2010 08:15
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
