Go to Post I can't claim to be an expert in the stess analysis field - I just play one on TV, er CD, er - okay, so call me a poser! - petek [more]
Unread 31-03-2010, 15:49
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
read joystick without cRIO attached?
Is it possible, with the 2010 FRC LabVIEW installation, to create a simple VI that will read a USB joystick and display the x and y axis output on a front-panel indicator, without having a cRIO attached?
Our programmer tried for an hour to do this but couldn't get it to work. He says it works fine when the cRIO is attached.
There must be a simple solution to this, no ?
Unread 31-03-2010, 16:02
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: read joystick without cRIO attached?
Yes it is possible, but not with the FIRST Library. Go to Connectivity->Input Devices.
Unread 31-03-2010, 21:15
Ether's Avatar
Rookie Year: 1969
Thank you Joe. Greatly appreciated. I phoned your answer to the programmer and he was able to get it working. (He is working on some new ideas in the hotel room tonight).
Joystick Read modification to breakout joystick buttons sparks-1784 NI LabVIEW 2 02-03-2010 14:54
Joystick Read VI and Passing Variables to the Control Stealth NI LabVIEW 3 24-01-2010 12:59
Axis camera without the cRIO CrazyCarl461 NI LabVIEW 12 17-01-2009 10:53
pic: 1741 and 45 overly attached Bruce Newendorp Extra Discussion 5 03-03-2008 19:13
Getting attached to your robot Jherbie53 General Forum 13 02-03-2008 14:42
