Re: BLINKING RED LIGHT!
I had this same issue, it's the voltage. Mine stalled and after a few seconds then reset. But i replaced the problem Jags with Victors and
bingo off to work we go. |
just wondering...
do victors "reset" or go into an "error state" when their voltage dips too low? The gearing in our drivetrain is high, which draws a lot of power from our battery. It seems that when our wheels stall from say running into the wall we run into the problem mentioned above with blinking red lights and the robot pauses for about 3 secs(about the time to reset a jag)... we are hoping that switching to victors will get rid of this problem, does this sound like it will work? thanks |
Brian, The Victors do not have the same current protection the Jaguars do, they will keep running during the conditions described. It is very possible that you would just move the fault upstream to the breakers by switching the speed controllers however. |
| Jaguars Blinking Red | shaggy0928 | Electrical | 4 | 03-02-2010 20:56 |
| Jaguar Red Blinking Light | RMS11 | Programming | 4 | 23-02-2009 09:18 |
| Program State red blinking | Generalx5 | Programming | 11 | 05-04-2007 19:01 |
| Blinking Red Light | teh_pwnerer795 | Programming | 8 | 21-12-2006 23:13 |
| Program light is blinking red | elsacr | FIRST Tech Challenge | 1 | 27-02-2006 10:23 |
