Go to Post The version that finished nationals was about 50% aluminum and 50% the original PVC and we never had any member break. (structural member, not team member). - Gary Dillard [more]
Unread 01-04-2010, 22:15
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
Rookie Year: 2010
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
PROGRAMMERS: WIND RIVER C++ vs LABVIEW vs JAVA
WHICH SOFTWARE IS THE BEST AND EASIEST TO USE TO PROGRAM A ROBOT, AND WHY YOU THINK IT IS?:
-WIND RIVER C++
-LABVIEW
or
-JAVA
to start, i choose windriver c++, because its the only language i know lol
Unread 01-04-2010, 22:19
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Re: PROGRAMMERS: WIND RIVER C++ vs LABVIEW vs JAVA
C++ is my favorite language, but I never used windriver, but I heard to was a $@#$@#$@#$@#$@# to use...
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 01-04-2010, 22:26
gr8dragon's Avatar
gr8dragon gr8dragon is offline
AKA: Parth Patel
gr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of light
I prefer C++ because its the first language i was introduced to.
I like Labview as it is not the same text coding I have been used to for a long time.
However we chose not to use Labview over Windriver because we thought that having a bunch of those connecting wires might get harder and harder to trace.
I guess I really haven't used it too much besides basic robot functions and one sensor.(Pot)
We kinda just said not to use Java and it was rather arbitrary.
Unread 01-04-2010, 22:29
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We like LabVIEW because we can do real-time analysis of things without re-downlading. Like making graphs vs Time of data points, probing data, and changing cal points. However, the largest negative I have is the build and download times. I once timed a build at 2 mins 41 seconds. The downloads are more reasonable, at around 1 minute. Overall, I would prefer LabVIEW over C++.
Kettering Motorsports
Unread 01-04-2010, 22:39
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
Personally I wouldn't call LabView coding at all...
Unread 01-04-2010, 22:47
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
Then what is your definition of programming?
I personally define programming as using a language that is turning complete to get a job done. Using Labview fits that definition, so I'd personally call using it programming. I may not enjoy using the language, but I personally don't let that effect my view about whether using it is programming or not.
Unread 01-04-2010, 22:49
apalrd's Avatar
More Torque!
VRC #3333
LabVIEW IS coding. It's used often in the real world (although not on production things, many companies use it for testing and experimentation), its optimized to run on cRio's, can run on the FPGA too (although FIRST won't let us do that), has networked front panels, can execute C libraries (using Call Library Function), can run parallel tasks (multithreading) super-easily (try making two WHILE loops in C++ that run in parallel, you won't be able to do it as easy as you can in LabVIEW), the ability to make asynchronous calls easily (static VI ref + Invoke Node), built-in toolkits for PID, fuzzy logic, and toolkits available for many more cool things, through a number of sources, comparable to many C++ libraries. If you are just saying your language is better than LabVIEW, while I see how you could consider C++ or Java "real" programming, LabVIEW is real code too, it runs just as well, it is super-easy to debug, and it's alot easier to code then C++ or Java.
Unread 01-04-2010, 22:50
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
But I will bet you C/C++ was used to program that LabView
Unread 02-04-2010, 19:55
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
Deep down, isn't Java just C/C++ code as well? It means squat that LabView is built off of another language. It's still a language.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 02-04-2010, 20:42
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
My opinion is all this contains.
I used Java to program the robot this year. Last year, I used LabVIEW. And to be honest, once each was on the robot, I didn't see any difference in performance. We also didn't get any complaints from the drivers.
I'm probably going to try C++ next year.
I'm not an experienced programmer. I started programming on the TI graphing calculators, with the built-in BASIC-like language. Moving to LabVIEW was something different, and JAVA the same. And I can say - again, my opinion - that for this application, I didn't see that one was particularly better than the other.
I'm probably still going to learn Java and C/C++ for programming for the computer. LabVIEW programs can run on a computer, but that doesn't mean it's inexpensive to do so.
Thus, does being proprietary and costly make a language better or worse? Or does it merely make it more exclusive? And, is exclusivity a bad thing?
And as for LabVIEW not being programming: My opinion is that anything that is compiled into native code and executed on a computer is a programming language. This may not be accurate - I'm in 10th grade and starting programming, so correct me if I'm wrong in that definition - but LabVIEW fits it, and so to me is real programming.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 02-04-2010, 21:00
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Rookie Year: 2007
Robototes2412 is on a distinguished road
Java is faster than labview
dissassembled, labview code makes random calls that waste cpu cycles. Java code doesn't
Unread 02-04-2010, 22:12
Bravo Ethan Miller. Very well said. That is the sort of attitude that makes it rewarding to work with FIRST.
Greg McKaskle
Unread 01-04-2010, 22:54
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
When I saw this thread I thought "Over/Under 5 posts before some throws out this particular flame" Looks like it a push and I was right on. This argument is getting old and predictable.
My team uses C++ because that is what works best for us. All 3 languages are coding. I suggest everyone try to learn all 3 of them. Trying to argue that any one language is better for programming FIRST robots is a meaningless pursuit, it is all based on personal opinion. They certainly have their own pros and cons (which are fine to discuss) but all are equally capable. Try to focus on what you would tell a rookie team trying to choose between the 3.
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Unread 01-04-2010, 22:58
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
I personally will tell the said rookie team to pick up a C++ book and read it and study and meditate on it, IMHO its way more useful in the real world out of the 3. If you learn C++, you pretty much know Java (except alot of the java specific stuff), won't take you very long to pick up on java. Plus most real world applications are in C/C++, like Operating Systems, Games, and tons of stuff.
  #15   Spotlight this post!
Unread 02-04-2010, 10:24
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Right... the 'real' world... and how many years have you been working in the software industry now?
It just depends on where you end up in the 'real' world. Different languages are better for different tasks. There is a lot to be said for domain-specific languages (such as Matlab) and scripting languages (such as python). Just depends on what you're trying to accomplish and what you're used to.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Wind River Cds Team1710 C/C++ 0 22-09-2009 10:57
Uninstall Wind River Lord_Jeremy C/C++ 0 15-01-2009 15:56
SVN wind river Mr.Macdonald C/C++ 3 13-01-2009 12:40
Wind River Help BenB Programming 3 02-01-2009 21:42
Open Wind River excel2474 Programming 12 31-12-2008 17:36
