Go to Post "FIRST is not about getting as little help as possible - In fact, it's the opposite- the goal is have to make you feel obligated to thank as many people as possible for helping you in ways that you didn't really think you needed or even considered that you could use help." - boomergeek [more]
Unread 02-04-2010, 15:16
Weird Al/ Tony Weird Al/ Tony is offline
Weird Al the Creator
AKA: Anthony. or Tony, not Toni i'm a guy!
FRC #1322 (G.R.A.Y.T. Leviathons)
Team Role: Student
Rookie Year: 2010
Weird Al/ Tony is an unknown quantity at this point
Send a message via AIM to Weird Al/ Tony
Will a 1/3 horse power sump pump motor burn up at half power?
I am building my own battle bot and I'm working on running it off of two 12V batteries. It will be driven by two heavy sump pump motors. I will only be able to obtain a possible half power off of the batteries and I need to know if that will ruin the engines. I have been told it will by a freind but I dont beleive her. So I need some help. I dont want to waste/ruin the motors after all!
I am Weird Al and I'm here to play! Check out the team:www.team1322.org !
Unread 02-04-2010, 16:52
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: Will a 1/3 horse power sump pump motor burn up at half power?
OK, There's not quite enough info here but I'll give it a try.
By "only be able to obtain a possible half power off of the batteries" do you mean that the pump is 24V and you are running it at 12V? If so, then your friend is absolutely correct. The motor will try and do the same amount of work with only 1/2 the voltage thus requireing twice (roughly) the current. This will heat the motor more.
In addition, most sump pumps are designed to work submerged in water. They use the water to cool the motor, thus will need extra cooling if it is run using air to cool it.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 02-04-2010, 17:04
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
What are your loading conditions? Do you have a model number for the motor so that we might be able to better understand? Are you using the batteries that we used for competition or are these some other chemistry (NiCd, Li-ion)? are these batteries in series, parallel, or individually connected to the motors?
Why are you only able to obtain half power? How are you gearing this drive train? wheel size? wheel traction? In general, depending on the loading condition, the power your motor demands is not a static number
Will it burn up? Well that depends a lot on the motors thermal constants (casing, efficiency, etc) and it's ability to handle a stall current among other things
More information is required to give you a good answer.
Unread 02-04-2010, 22:53
Team Role: Student
Rookie Year: 2010
when I posted this I knew nothing about the topic I was asking about. so here arwe the facts. I have a 115 A/C volt motor, I'm using a 12 D/C volt battery to power it. the motor is 5.7 amps, 60 hz, 1725 RPM, and it is non submersible. air cooled and isnt ment to be wet. I have a model #: xqj48517028j p and I ndont know what the p means. it also says it is thermally protected, single phase. what is single phase? and it is 60 cycle? what is that. fla= 5.8 sf= 1.0 and I have no clue what any of that means. help me out, thanks.
Unread 02-04-2010, 23:57
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
My guess is that you won't be able to run it directly off the 12 bolt battery. It sounds like it uses the 110 volts out of your wall which is single phase. I.E. there is only one sinusoidal wave coming out of your standard wall outlet. (opposed to 3 sinusoids in 3 phased 220 volts). 60 cycle refers to the 60 hz which is the frequency of the sinusoid in your wall.
The thermal protection most likely means that the motor will stop running if it gets to hot to prevent it from damaging itself.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 03-04-2010, 00:08
Team Role: Student
Rookie Year: 2010
well what are sinusoids. and it is a wall plug type motor. so that means like even if I wanted to I couldnt convert it? and what about like wheelchair motors cause I got those. and I mean what if I used like a fan motor from a like normal around the house use post fan or whatever? would i not be able to use that with a battery.
Unread 03-04-2010, 00:14
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Sinusoid are sine waves. You would need an inverter to go from the DC of the battery to AC but most inverters do not produce a true sine wave. A regular house fan is mostly likely an AC motor; all mine are. You could maybe use a fan motor off your PC which is a DC motor.
The wheel chair motors are mostly likely DC so they could be usable.
Wikipedia has good info on AC and DC
Kevin Li
596 - Sciclones
Unread 03-04-2010, 00:19
Team Role: Student
Rookie Year: 2010
alright thanks. ya see I'm trying to get a powerful motor that will be hard to stop while it is receiving power. that way it will be able to power my robot through all opposition. (this robot is for like a hobby, not the competitions) and I'm thinking that I have some older wheelchair motors, and other stuff. but they arent very fast and they dont have much power. I'd probably need either a gear box or some good belts to allow diffrent speed and torgue. I kinda think I know what i'm talking about. I mean I'm just getting on a team so I dont have alot of robotics experience.
Unread 03-04-2010, 00:22
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Go FIRST Retro and use some 12 Volt Drill Motors. They'll come with gearboxes with high low speeds too! Judging by your team number your team might still have some.
Kevin Li
596 - Sciclones
Unread 03-04-2010, 00:32
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I think that you may want to talk to your local physics teacher. At the least, he can help you through some of the concepts and the math behind them.
I'll give a brief rundown of some of them.
Voltage: difference in electrical potential energy between two points.
Amperage or current: how fast that electrical energy can move.
Power (or energy): force*distance.
Work: power/time.
Torque: force * distance, usually referenced with regard to rotational motion. You'll want to know this eventually.
Gearboxes multiply and divide torque and rotational speed, which translates via wheels to linear power and linear speed.
BTW, you may want to look up some of John V-Neun's whitepapers. I think that those will help you with some of the math that is behind the design of a drivetrain, and quite possibly help you optimize the drive for the motors you have.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 03-04-2010, 01:18
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
power and energy are not the same thing.
Work: power/time.
you have that backwards.
power = work/time
torque translates to linear force, not linear power.
Unread 03-04-2010, 01:40
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
They aren't, but for some reason known to nobody, they share the same units. Joules in the SI, BTU and its equivalents in the Eng. system. (Eng. == either English or Engineering, which for functional purposes are indistinguishable.) This makes the calculations very similar when all's said and done.
150 kJ << without my telling you, is this power or energy?
150 kN-m << That's power, but to get that I had to expand the unit. Also note that that is a torque unit as well.
Energy has a number of ways to get to the kJ unit, none of them simple. Something about energy/mass * mass in a number of weird combinations makes it a little hard to translate out of handwriting.
Past teams:
Unread 03-04-2010, 01:50
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Power is measured in Watts. Energy is measured in Joules.
Work and Energy have the same units. Power and Energy do not. Think about it, to find power Power you take the derivative of work with respect to time. This will divide the units of work by time.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Well thats energy because power would be j/s.
And I don't think its torque because you're not taking the cross product
Kevin Li
596 - Sciclones
  #15   Spotlight this post!
Unread 03-04-2010, 07:28
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Al,
It not a simple matter of voltage in this case. A motor turns by using magnetic fields. In DC motors, the fields are generated via permanent magnets in the case and the current through the windings. In AC motors, there is generally no magnets and no brushes. The magnetic fields are generated by the AC current flowing through the motor windings and the induced currents that flow in other structures in the motor. Connecting this sump motor to a DC battery would cause it to heat up over time but it would never move.
Al
WB9UVJ
www.wildstang.org
________________________
Power distribution board does not give power to access point bitsoglass NI LabVIEW 3 17-02-2009 12:07
Backup battery will not power RC steven114 Control System 13 24-01-2005 01:59
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
J&J Midatlantic - will power be in stands? Ben Mitchell Regional Competitions 2 13-01-2003 16:07
Power Wheels parts needed: Will trade, sell soul, etc. archiver 1999 13 23-06-2002 22:27
