Re: Regarding The cRio
Just putting this out there, I've been an inspector at 3 regionals(WPI, Boston, and CT) and the inspection checklist has always included this line:
-Eric |
It would not be worth the added power. The cRio has so much power, most teams do not get anywhere near fully utilizing the cRio. Plus, using two cRios would be extremely restrictive on the rest of your robot (cost wise).
Right now, I notice the severe lag from doing two or more circle detections per cycle, and this only adds up to about 10-15 times per second. Does anyone think asking FIRST to ease this restriction concerning BIOS batteries for next year would be option? |
They don't have to know what they don't know... Just enclose it in a regular pc caseedit: Or even more bad $@#$@#$@#, use 1 or more ps3's on board, they are like $300 each, so its legal. Just use a enternet hub and boot up linux on it... BAD $@#$@#$@#!! Last edited by davidthefat : 02-05-2010 at 20:22. |
That's a very neat idea, but really, the Cell is just a CPU on steroids. And thus, it's a CPU which can't compare to a GPU's performance, even though it's easier to code. It's like trying to compare anything to infinity.
Unfortunately, a PC case would probably be a big weight and shock-resistance hassle. These components already have to withstand huge Gforce shocks, even with bumpers. Kudos for the idea, though. That'd be interesting, seeing my neon-blue case on a robot. |
http://www.ibm.com/developerworks/po...pa-linuxps3-1/ |
Don't update your Ps3 then. Linux support just got dropped.
Im aware, gah no PSN for me now |
Oh my goodness! I forgot the fact that the cRIO has a serial port that can be used to do this stuff. If you use an absurdly high baud rate (with a heavy dose of custom code, of course) and hook up a crio to, say, an arduino over serial (hook up the tx and rx to digital ports 0 and 1), you could have a co-processor work. I'm going to experiment with this and i will keep you posted.
#10
No it isn't. http://www.arduino.cc/en/Serial/Begin I've run mine at 115200 and it works fine.
#12
Isn't that still a seriously low level of bandwidth?
I guess knowing what you are passing back and forth, it might only have to come down to raw, simple data that gets proccessed, and the results are passed back just as simply, but still... |
#13
If you are seriously considering an arduino, then why don't you use one of the ethernet shields?
http://www.adafruit.com/index.php?main_page=product_info&cPath=17_21&produ cts_id=83 http://www.sparkfun.com/commerce/pro...oducts_id=9026 that would leave the serial port on the cRio open, and dwould allow a network switch to combine several on the robot. The sparkfun shield communicates over SPI, which theoretically has a higher bandwidth then the serial comms that it is replacing |
#15
At minimum, I'd imagine this would violate <R22>. I'm not aware of any other rule that would specifically prohibit this, but I'm also not aware of any reason to use more than one cRIO on one robot.
| Reimaging the cRio Issues there are no cRio devices on the subnet | Stuart | FRC Control System | 2 | 25-02-2009 23:41 |
| Question about Rules regarding the cRIO | tbd | FRC Control System | 1 | 08-02-2009 12:52 |
| What are the rules regarding joysticks, etc. for the Operator Interface? | itay_ms | Rules/Strategy | 1 | 17-01-2007 12:16 |
| An excellent discussion on #firstrobotics regarding Vex and the future of the US | sanddrag | General Forum | 18 | 25-03-2006 17:56 |
| Regarding <G13> - placement of the tetra by the human player. | Leav | Rules/Strategy | 7 | 02-02-2005 10:26 |
