Go to Post In my opinion, I wouldnt want gifts or praise from people about my help to a robotics team, all I would want is a thank you, that would make all my hard work and efforts worth while and it would prove to me that I could actually be making a difference in the students lives - Mike Schroeder [more]
Unread 04-04-2010, 22:50
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Regarding The cRio
http://sine.ni.com/nips/cds/view/p/lang/en/nid/203964
I am assuming that is the cRio that we get... Is it legal to used a 2nd crio on your robot? Its a PowerPC based controller... Thats interesting isnt it? My mentor said that he was willing to buy another cRio for me to practice on, so why not use 2 on the robot?
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 04-04-2010, 22:53
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Rookie Year: 2007
Robototes2412 is on a distinguished road
Re: Regarding The cRio
Umm, i dont know. i do have a quick question for you though. Are you prepared to have two robots to program for? They cannot have any communication with either eachother or the world, and there is only one gaming adapter. At most, i'd use an arduino, but a whole other cRIO, i wouldn't.
Unread 04-04-2010, 23:00
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
My mentor thinks its most wise to work on the processor the final robot would have... I want to use 2 cRios on one robot because I think a ATmegaa284p won't have enough juice to run the image processing from multiple sensors very efficiently...
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
Hmmmm...
<R56> ROBOTS must be controlled via the programmable National Instruments cRIO-FRC (National Instruments part number 780406-01). Other controllers shall not be used.
Custom circuits and additional electronics are allowed to utilize the Port 2 Ethernet bus and/or the CAN-bus to communicate between devices. Note however, that the ROBOT must be controlled by the cRIO-FRC (see Rule <R56>). Thus, any additional devices on the Ethernet or CAN-bus must not provide command signals that do not originate from the cRIO-FRC It is our intent to incrementally open access to the full control system technologies in a controlled manner that reduces the risk of “unanticipated surprises” as we gain experience with the system.
That's what the competition manual says; I'm not sure how to interpret it or how you plan to use the other cRIO.
Edit: And also <R22> as mentioned above.
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 04-04-2010, 23:03
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
Originally Posted by Al3+ View Post
Hmmmm...
I have a theory that you can use the port 2 ethernet port and connect the crio from the port one. Some one end of the enternet goes to the # 1 port then into the #2 port of the other and the camera goes on the 2nd post of #1
Unread 04-04-2010, 23:05
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
As far as communications go, the second ethernet port on the cRio (one that communicates to FMS) can be used to talk to the second cRio.
<R68> All outputs from sensors, custom circuits and additional electronics shall connect to only
A. other custom circuits, or the following:
B. additional COTS electronics, or
C. input ports on the Digital Sidecar, or
D. input ports on the Analog Breakout, or
E. the RS-232 DB-9 serial port on the cRIO-FRC, or
F. the Ethernet bus connected to Port 2 of the cRIO-FRC,
Emphasis mine.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 04-04-2010, 23:07
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
Emphasis mine.
Its also probably possible to hook up another microcontroller as a Digital I/O
Unread 04-04-2010, 23:14
biojae's Avatar
Which is correct, but if you have an ethernet port on your microcontroller (or 2nd cRio) why wouldn't you want to get 1 or more megabytes per second throughput?
Going through GPIO is going to be slower then ethernet.
Unread 04-04-2010, 23:21
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
If I have an ethernet port on the microcontroller (not a 2nd cRio) where would the camera plug in if the 2nd port is used up? Not using it on the microcontroller, its too much for it
Unread 04-04-2010, 23:28
biojae's Avatar
According to this Q&A post : http://forums.usfirst.org/showthread.php?t=14423
"<R68> Says the Ethernet bus connected to Port 2 of the cRIO-FRC may be used.
Does this mean that a network switch may be used to communicate between devices on the bus as long as the command signals originate from the cRIO-FRC?"
Yes.
Now keep in mind that rules change from year to year, these are only this year's.
Unread 04-04-2010, 23:29
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
A network switch! Never thought of that
Unread 04-04-2010, 23:40
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
If I recall correctly theres a rule somewhere restricting the amount you can spend on a single electronic components. I think it was $400, so that excludes the cRio (which you can get one at a discount from NI for something like $1500 I think).
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 04-04-2010, 23:41
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
I don't think you can count an extra cRIO as KOP component. Also, would the cost be considered 750 or 1400 dollars (the offseason rate vs full)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
http://zone.ni.com/wv/app/doc/p/id/wv-1291/nextonly/y
  #15   Spotlight this post!
Unread 04-04-2010, 23:52
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
http://www.robotshop.com/roboard-rb-...omputer-2.html
this sounds like a better investment: its cheaper (way cheaper) and its C++
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
Question about Rules regarding the cRIO tbd FRC Control System 1 08-02-2009 12:52
What are the rules regarding joysticks, etc. for the Operator Interface? itay_ms Rules/Strategy 1 17-01-2007 12:16
An excellent discussion on #firstrobotics regarding Vex and the future of the US sanddrag General Forum 18 25-03-2006 17:56
Regarding <G13> - placement of the tetra by the human player. Leav Rules/Strategy 7 02-02-2005 10:26
