Go to Post Gracious professionalism... otherwise, the program has failed. - Yan Wang [more]
Unread 05-04-2010, 16:20
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
Team Role: Leadership
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Smaller Diameter Wheels - What's the advantage?
This year, I saw many veteran teams using wheels with smaller diameters than what I'm used to seeing and what my team has used in the past. I've seen lots of 4 inch wheels and some 5 inch wheels, as compared to the 6 inch wheels that my team uses and some of the KOP and Plaction 8 inch wheels that I've seen lots of rookie teams use.
What are the advantages of using these smaller diameter wheels? Of course, you can change the speed/torque ratios through chaining and gearing, so I don't think that's the issue. There is an obvious weight difference too, but I'm not sure if the weight loss is justifiable. The only other thing I can think of is the decreased amounts of rotational moments of inertia (smaller radius, less mass), leading to less strain on the motors when the robot accelerates or decelerates. Though, I am unsure if these are reasons at all for a team to choose smaller diameter wheels.
Are there any reasons as to why smaller wheels are advantageous over larger diameter wheels? If your team uses them, or if you know any good reasons, please share some insight.
Thanks!
-Logan
pic: Variable Diameter Wheels? In Vex?! - pic 1 artdutra04 Extra Discussion 2 07-09-2006 20:53
pic: Variable Diameter Wheels? In Vex?! - pic 3 artdutra04 Extra Discussion 13 07-09-2006 17:37
The advantage of holonomic drivetrains KrazyRoadster Technical Discussion 28 12-04-2006 19:29
Variable Diameter Wheels greencactus3 Technical Discussion 71 12-12-2005 22:58
Why the smaller wire gauge? sanddrag Electrical 3 09-01-2005 11:53
