Go to Post Wisdom is knowing the difference between "the way to do things" and "the right way to do things." Just because an action may be physically possible does not mean that it is smart to do. - dlavery [more]
Unread 05-04-2010, 20:41
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
Rookie Year: 2007
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Code works fine until build?
So we were testing out an addition to the dashboard, which would use FTP to get log files we made. It works fine in the Labview editor-it runs fine and it gets the files. Unfortunately, when we build it and run it, it errors on opening a connection. We've tested this multiple times, but it doesn't change. It says that there's an error #54, which is a Labview error of some kind, not an FTP one. Does anyone have any advice about how to go about fixing this? We kinda need this, but nobody here really knows how to use labview, we taught ourselves.
GSR Dean's List Finalist 2011
Unread 05-04-2010, 22:27
Re: Code works fine until build?
To lookup a LV error, use Help>>Explain Error
54 returns
LabVIEW: The network address is ill-formed. Make sure the address is in a valid format. For TCP/IP, the address can be either a machine name or an IP address in the form xxx.xxx.xxx.xxx. If this error occurs when specifying a machine name, make sure the machine name is valid. Try to ping the machine name. Check that you have a DNS server properly configured.
As for why this happens in a built app, do you use one of the path constants, or a property node to read a path or name? If you don't figure it out, perhaps you want to attach it for others to see.
Greg McKaskle
Unread 06-04-2010, 18:52
AKA: Matt Soucy
Rookie Year: 2007
Never mind, it was something wrong with my computer...I should probably find out what was wrong with it, but in the meantime, it works fine on the actual dashboard and another person's computer.
Camera tracking code not working in our own program, but works in CircleTrackerDemo TPNigl Programming 3 31-01-2010 19:40
0.00 Volts - Code Not Downloading - Randomly Works? R.C. Electrical 7 26-08-2009 13:52
Time to build cRIO LabVIEW code Terry Sherman FRC Control System 10 05-03-2009 01:10
Run works but build&deploy doesn't program1 NI LabVIEW 3 03-02-2009 22:32
Some Blank Code That you Know works chantilly_team Programming 5 18-01-2005 22:00
