G16 question
All,
G16 states: <G16> BALL Return - HUMAN PLAYERS must place BALLS on the BALL RETURN using the TRIDENT. No other means are permitted for TEAMS to return BALLS to the FIELD. Violation: Two PENALTIES and YELLOW CARD. You would think that deflecting the ball before the ball touches the playing field would be a G16 penalty. Roy |
Re: G16 question
How do you come to that? G16 is clearly referring to how balls get back on the ball return (via the trident). It doesn't have anything to do with what's "allowed" to happen after it leaves the trident....
Re: G16 question
If the point of this thread to go after a certain team, please redirect your comments to the other threads.
Re: G16 question
You're on the wrong rule. <G16> only governs the actions of the human players returning the balls to the field--they have to be placed on the return, using the trident. Once they're on the return, a different rule governs not contacting a ball in contact with the return, and another one governs contact with the return and return bars.
I know why you're asking the question. For your own good, I would suggest not asking further, as the topic can easily rub someone the wrong way, especially after it's been discussed ad nauseum for the past 3-4 weeks. |
Re: G16 question
Ball deflectors touch balls after HUMAN PLAYERS place BALLS on the BALL RETURN. Clearly you're really reaching here.
Re: G16 question
I think he's referring to the "No other means are permitted for TEAMS to return BALLS to the FIELD" section. While i can see how he's interpreting it, I think this is more an attempt to "lawyer" the rules than take them for their true intention. This rule involves the act of team members (not robots) returning balls into play. The only legal way of doing so it by placing the ball in the trident, then using the trident to place it on the rack (per the first sentence in the rule). The second sentence, IMO, is solely there to ensure players know it's illegal to, for example, simply throw the ball over the wall.
Re: G16 question
You are misunderstanding the definition of TEAM. The ROBOT is not part of the TEAM.
Re: G16 question
Alex,
My intent is not to go after a team. I am simply asking a question and was wondering how other people interpret the G16 rule. I'm not a lawyer either. Roy |
Re: G16 question
Short answer: It is to prevent HP's throwing the ball in to the field, say straight to their robot, instead of putting the ball in at midfield. Once the ball clears the return counter, it's protected by another rule until it breaks contact with the return, at which point it's whoever gets to it first, via deflection or a lucky bounce off the ground. |
#10
Re: G16 question
469 doesn't need any defense from me, but since we built a looper similar to 469 (but nowhere near as awesome, since we can't get the returned balls all the way back to the goal) I'll give you our team's interpretation of the rules. Seemed like to us they were pretty straight forward, I have a hard time seeing where all the confusion comes from. The initial poster seems to be thinking that RETURNED TO THE FIELD means that the ball has to touch the carpet. This is NOT true, otherwise you would keep getting DOGMA penalties until the ball hit the carpet. The ball is consiered RETURNED TO THE FIELD as defined in <G16> once it passes the ball return timer, which is obvious once you read <G17>. <G47> controls what happens once it passes the timer.
Says teams have to place balls on the BALL RETURN rails using the trident. Quote:
Nothing to stop you from doing anything you want to with it once it comes off the rails! Last edited by 45Auto : 06-04-2010 at 19:01. |
#11
Re: G16 question
OP question is answered in multiple ways. Let's close the thread before there are anymore misunderstandings ![]() Last edited by The Lucas : 06-04-2010 at 19:05. |
#12
Re: G16 question
Can I second the motion?
#13
Re: G16 question
The definition of the FIELD in 6.2.1 can also be interpreted such that the FIELD is a 3D volume, not a 2D surface. As noted, <G17> and <S02> reinforce this, as does 7.3.5.1 "Robot out of Bounds".
Closing. |
| <G16-G18> question | Daniel_LaFleur | General Forum | 6 | 10-02-2010 15:39 |
| GP question | kamocat | General Forum | 6 | 25-11-2009 14:27 |
| 8.2.1 <R6> Question | Brandon_L | General Forum | 6 | 10-01-2009 20:40 |
| Servo behavior question / advanced servo/PIC programming question | DanL | Electrical | 12 | 18-10-2005 18:33 |
| Question | OakCrewz | OCCRA | 2 | 30-10-2002 18:06 |
