INFRARED SENSORS
can any one please assist me on how to program an infrared sensor in autonomous mode, and give a sample code for it in windriver c++?? (i never learned how to program any)
Re: INFRARED SENSORS
"Programming" an input is just a matter of reading its value and testing it to decide what the program should do. What do you want the program to do?
What output does the sensor provide? If it's the equivalent of a switch, it goes to a digital input. If it's a varying voltage related to the distance from the sensor to the target, it goes to an analog input. You can do anything in the autonomous routine that you would do in teleoperated mode. PWM pins on the Digital Sidecar are outputs only. They can't read sensors. |
InfraredSensor->Get() will return the state of the input. This method is featured prominently in the documentation for the DigitalInput class, isn't it?
It will return a boolean value. Typically true means the signal on the DIO pin is a high voltage (5v) and false means it is a low voltage (0v). Since there is a pullup resistor on the input, an open circuit will read true and a switch closure to ground will read false.
I don't really understand the rest of your question, but the documentation should answer anything you need to know. |
InfraredSensor->Get() has no parameters, so nothing needs to go inside the parentheses. I think that was the question.
You want something like Code:
if (InfraredSensor->Get()) myRobot->Set(0.0); |
Thanks alot!!
| InfraRed Problem | tbd | Sensors | 10 | 27-01-2008 02:01 |
| where can we buy hall effect sensors or gear tooth sensors | amirjpl | Electrical | 3 | 13-02-2006 11:02 |
| IR (infrared) sensors | Chris.Steimel | Electrical | 5 | 11-02-2005 18:46 |
| IR (infrared) sensors | Chris.Steimel | Programming | 0 | 09-02-2005 18:04 |
| InfraRed = gps ? | nzj1 | General Forum | 17 | 11-01-2004 16:58 |
