Go to Post Sounds like a silly idea... so of course I'm in. - George1902 [more]
Unread 09-04-2010, 18:39
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
The weirdest thing ever.
We have a compressor on our robot and we need to charge it out in the match waiting line because it has a small leak and drops significantly. So we tether it out around the field and it charges the tanks. Well the weird thing is that it gives a strange time issue, the time starts and stops erratically, and displays a watchdog error. It wouldn't be that strange if it happened all the time. But it only happens out around the field. In the pits we set up the same conditions, no problem, on the field we set up, no problems. This isn't a severe problem the tanks still get charge up and everything its just strange.
Any ideas on why this is happening. Is the field surrounded by a forcefield that I should know about.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 09-04-2010, 18:48
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: The weirdest thing ever.
Probably a coincidence with it being on the field only, but I've seen this problem before. It's a problem with the camera and the WPI code. If the camera hasn't finished initializing, the console is flooded with errors until the camera finishes loading (ring turns green). The flooding slows down the rest of the system enough that watchdogs trip and halt the robot intermittently.
If you wait for the ring around the camera to be green before enabling the bot (and an image is showing on the DS if you have it referencing the camera in robot init), there shouldn't be any freezing
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 09-04-2010, 21:35
DonRotolo's Avatar
Back to humble
FRC #0832
Mutually exclusive statements.
Fix the leak; 1 PSI loss per minute is easily achieved. Saves grief in queue, too.
Get a small cup of soapy water, pressurize the system, and paint the entire pneumatic system (with a 1/2" paintbrush) at every connection. Include the two connections on the compressor head, and the connections between parts of the pneumatic valves. Any bubbles that form and grow indicate leaks; tighten the connection/replace the teflon tape/cut the hose end square to stop the leak.
Unread 09-04-2010, 21:51
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
First, welcome to Galileo! I'm glad you could make it in as a late addition. I believe we will be pit neighbors (365 & 379 in Galileo) and I would be happy to take look at your code for potential watchdog issues (camera sounds like a likely one as mentioned). Also, I'm sure we have someone who could help find the leak.
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Unread 10-04-2010, 13:00
FRC #0379
On the leak part we found i think it was 3 leaks and fixed them (with the soapy water trick) but there still is a small leak somewhere. On the camera we don't even have one attached (would it be bad to leave the ethernet cable for the camera plugged into cRio port 2 to remove the possibility of error of plugging the radio into port 1).
Edit: Woot Galileo.
Unread 10-04-2010, 13:33
AKA: Ian Thompson
Rookie Year: 2010
Well if it isn't the camera there still are a few things that can cause the same error (jag not communicating over CAN, printfs in the code, anything that prints to stdout)
Unread 13-04-2010, 18:24
FRC #0379
We have no jags to communicate over the CAN with.
Unread 15-04-2010, 00:57
FRC4ME FRC4ME is offline
FRC #0339
Rookie Year: 2007
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
When the problem occurs near the field, and when it doesn't occur in your pit, are you using the same tether cable?
Go directly to queue. Do not pass pit.
The most amazing thing I have ever seen. sanddrag Chit-Chat 4 03-01-2007 03:22
The strangest thing you'll ever see BuddyB309 Computer Graphics 7 17-10-2005 22:43
pic: What's the weirdest thing you saw at Ramp Riot 5? CD47-Bot Extra Discussion 8 15-11-2004 23:15
The weirdest thing w/ duct tape... Matt Attallah Chit-Chat 70 11-03-2004 13:51
The dumbest thing you've ever done EVER! Aaron Lussier Chit-Chat 24 22-06-2002 01:05
