Go to Post If you find yourself extremely upset, frustrated, angry, or any other term of emotion, please stop and ask yourself why you participate in FIRST. - indieFan [more]
Unread 10-04-2010, 10:36
May_Walter's Avatar
May_Walter May_Walter is offline
Artemis #3083
FRC #3083 (Artemis)
Team Role: Coach
May_Walter is an unknown quantity at this point
measuring @ the arena
Hi
is it legal to bring along to the arena something like a straight object that'll be long enough for us to measure persicely and locate our robot's position before autonomous?
Team ARTEMIS - #3083 - The Sky Isn't The Limit Anymore!
2011- FRC Team Captain and Coach, FLL mentor & Ref. Semi-Finalists, Motorola Quality Award, Star of the Day.
2010 - FRC Team Captain and Coach, Engineering Inspiration Award, UL Industrial Safety Award
2009 - Coach, Judges Award, Finalists w/ 3075 & 1690
Unread 10-04-2010, 10:41
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
Team Role: Coach
Rookie Year: 2000
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Re: measuring @ the arena
<G11> ROBOT Alignment Devices - Alignment devices (templates, tape measures, laser pointers, etc.) that are not part of the ROBOT may not be used to assist with positioning the ROBOT. Violation: TEAMS that use external alignment devices to position their ROBOT will have their ROBOT arbitrarily repositioned by a referee before the start of the MATCH.
I want it to be noted it only took me a few seconds to find this rule.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 10-04-2010, 10:42
lscime lscime is offline
AKA: Luke Scime
FRC #2614 (Mountaineer Area RoboticS (MARS))
lscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to behold
Unfortunately this is probably NOT legal:
Good Luck!
-Luke
Unread 10-04-2010, 10:49
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Rookie Year: 2010
Chickenonastick is on a distinguished road
Trivially, if done so, would the referee attempt to sabotage your autonomous mode, or actually help you?
Unread 10-04-2010, 11:03
ATannahill ATannahill is online now
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
They will move you in such a way to undo any advantage that might have been gained by using that device. The refs would probably put you out of line with the ball.
- Arizona North
Unread 10-04-2010, 13:31
DonRotolo's Avatar
Back to humble
FRC #0832
It is most certainly legal for you to bring it, and to use it. But don't expect that your robot will remain in that spot after you leave the field, as per <G11>.
Unread 10-04-2010, 13:37
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Unless, of course, it is part of the robot.
Note that such devices attached to the robot would fall under extra scrutiny at inspection to ensure that they can't leave the frame perimeter during a match. It is also quite possible to have a ruling that you could not extend it before the match.
Your best bet would be to do a quick-and-dirty open sight across the top of your robot--block with a slot here, pin there, line them up through the middle of the balls, hope you fire correctly. If that would prevent you from going under the tunnel, use servos to move them out of the way during the match.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 10-04-2010, 13:38
XaulZan11's Avatar
XaulZan11 XaulZan11 is online now
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
If you had extra weight, couldn't you put it on the robot for the match so it would be part of the robot?
Edit: That Eric is soo fast in responding to questions!
Unread 10-04-2010, 14:57
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Or just put them on hinges or something, and fold them down by hand when you're finished aligning the 'bot.
Unread 10-04-2010, 15:49
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Referees will reposition randomly. They will/should not look at what you were trying to achieve. They will move the robot. I would expect that the amount of movement will be in direct proportion to how tired they are or how late in the day it occurs.
Al
WB9UVJ
www.wildstang.org
________________________
pic: Israel regional - the arena David55 Regional Competitions 19 29-03-2006 14:06
Question: What If The Ball Goes out of the Arena?... DanTheRobotMan Rules/Strategy 13 12-01-2006 18:20
Here is how the arena comes team222badbrad Off-Season Events 2 24-05-2002 19:26
