Go to Post Capability and willingness are two very different things. Anybody can dance, though you could spend your lifetime unsuccessfully trying to convince them of that. - Mr. Pockets [more]
Unread 16-04-2010, 17:21
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
Rookie Year: 2010
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
CAN ANYONE HELP ME PLEASE??
I wrote a this code for our arm release:
if ( (ThirdStick->GetRawButton(6) ) )
ArmRelease -> Set(1.0);
else
ArmRelease->Set(0.0);
if ( (ThirdStick->GetRawButton(7) ) )
ArmRelease ->Set(-1.0);
else
this means when i press buton 6 on the joystick the motor is supposed to go forward, and when i press button 7 on the joystick the motor is supposed o go backwards. button 6 work, the motor goes forward, but when i press button 7 it doesnt move. i even tried:
while (ThirdStick->GetRawButton(7)
ArmRelease->Set(-1.0);
else
but it still dont work!
Unread 16-04-2010, 17:30
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: CAN ANYONE HELP ME PLEASE??
Huge flaw in your code. Here's a hypothetical situation based on the first one shown:
Button is 6 is pressed. The motor is set to 1.0. However, almost immediately after that, button 7 is checked and most likely set to 0.0.
Here's what I think you want:
Code:
if (ThirdStick->GetRawButton(6)) {
    ArmRelease->Set(1.0);
} else if (ThirdStick->GetRawButton(7)) {
} else {
Also, I assume you mean if instead of while in that second code block. That version would only activate button 7 mode if button 6 was pressed
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 16-04-2010, 17:38
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
Rookie Year: 2010
Code:
} else {
THANKS ALOT MAN!!!!, I FORGOT ALL ABOUT ELSE IF STATEMENTS
I'm Starting a Team, Can you help me please? Leav FIRST Lego League 2 14-09-2006 15:14
can anyone please tell mw where or with what can i lear programing in C techsage Programming 7 23-08-2005 00:25
please help! anyone not using Filemaker Quentinfool Scouting 0 04-02-2003 21:53
Can Anyone Help????? archiver 1999 0 23-06-2002 22:58
Can anyone help me??? archiver 2001 1 23-06-2002 22:17
