Go to Post To me game hints are like robot teasers. Much ado about nothing and I ignore both. - Koko Ed [more]
Unread 17-04-2010, 13:29
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Swerve vs. Mecanum Programming
I have seen many people talk about the advantages and disadvantages of Swerve vs. Mecanum. I have seen one argument that a swerve is harder to program than a mecanum but I think it is the other way around. I have built at least 2 VIs (I use LabView) for a swerve drive and my dad has built at least 5. I still have yet to figure out how to program a mecanum drive.
So my two questions
1. What is you opinion on Swerve vs. Mecanum Programing difficulty.
2 Am I missing an equation or formula that can be used in programing a mecanum drive that makes it easier?
Unread 17-04-2010, 14:16
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Swerve vs. Mecanum Programming
Here are two simple algorithms:
2 JOYSTICK TANK DRIVE MECANUM SEPARATION OF VARIABLES
http://www.chiefdelphi.com/forums/sh...94&postcount=1
3-AXIS JOYSTICK MECANUM ALGORITHM
http://www.chiefdelphi.com/forums/sh...383#post916383
The above algorithms are not optimum, but they work.
Unread 17-04-2010, 14:42
buchanan buchanan is offline
FRC #2077 (Laser Robotics)
Rookie Year: 2007
buchanan is just really nicebuchanan is just really nicebuchanan is just really nicebuchanan is just really nice
Without getting into detailed equations, the mathematical principles of fully holonomic omni/mecanum drives are relatively simple and can be approached this way:
Each wheel has a direction vector along which it can transmit force in either direction. For a mecanum this is at 45 degrees to the plane of the wheel, parallel to the axle of the roller contacting the ground. For an omni it's along the flat plane of the wheel. No force is or can be transmitted except along this vector.
To get the wheel speeds necessary for any desired motion, you need to compute the projection of the motion vector onto each wheel's direction vector. For mecanums there's an additional constant to correct for the 45 degree angle. This can be done with dot products and no trigonometry.
For simple directional motion, regardless of direction, that's all there is to it. To handle rotation, the motion vectors are tangent to a circle about the center of rotation, projected on the same wheel vectors, and scaled by relative radius. For rotation about the center of a normally configured robot, these end up the same for each wheel. Rotation about other points or for odd wheel configurations is a bit more complex but conceptually the same. You can rotate and move simultaneously by solving the wheel speeds for each separately, then adding the motion and rotation components for each wheel to get its final drive speed.
This approach lends itself well to a two stick motion/rotation or single stick/twist control setup, and the vector math shouldn't take more than a couple of dozen lines of Java or C. It handles any motion physically possible with the robot. The motor drive functions needed for swerve drives, especially for complex motions, are considerably more complicated.
It should be noted that there are simpler but still useful ways to employ mecanum/omni wheels short of full holonomic, and other ways to program swerves short of the "almost holonomic" of which they're capable.
Unread 17-04-2010, 15:42
kgzak's Avatar
AKA: Kris
Thanks, that helped. Between you and Ether I figured it out. I thank both of you.
Unread 17-04-2010, 15:27
kgzak's Avatar
AKA: Kris
I want to be able to go any direction with mecanum wheels not just forward backward and strafe. I have seen it done before and want to use that to create a field oriented drive so I press the joystick in any direction and it moves in that direction.
Unread 17-04-2010, 15:43
Ether's Avatar
Rookie Year: 1969
The algorithms in both links allow all 3 degrees of freedom: forward/reverse, stafe left/right, and rotate clockwise/counterclockwise.
I want to use that to create a field oriented drive so I press the joystick in any direction and it moves in that direction.
The 3-axis joystick algorithm can be made field-oriented simply by doing a coordinate axis rotation of the X,Y joystick values before feeding them to the algorithm.
x' = xcos(theta) - ysin(theta)
y' = xsin(theta) + ycos(theta)
... but Buchanan's approach is technically more correct and will yield more optimal control (more accurate directional control, smoother operation, and less scrubbing of the wheels)
Unread 17-04-2010, 15:59
kgzak's Avatar
AKA: Kris
Thanks. That'll help. I think I have it figured out. Now if only our coach will do off season stuff
Unread 17-04-2010, 19:00
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
AM has a great powerpoint about omnidirectional drive, which has several diagrams that may make seeing the vectors talked about above easier to see.
http://www.andymark.biz/presentations.html
Also, if you use a gamepad or similar control device, using the left joystick to control the movement of the actual robot and using the right joystick x axis to rotate the robot, it makes it very easy for someone who has played Halo to figure out how to drive your robot.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 17-04-2010, 19:03
kgzak's Avatar
AKA: Kris
I was thinking that and since I am not only the programer, I am the driver I can basically make any driver station I want.
Unread 17-04-2010, 19:21
AKA: Alex
Then use whatever works for you. We need to get a gamepad to work with Java before we start to tackle programming a swerve...
-Alex
Unread 21-05-2010, 21:15
tanguma26 tanguma26 is offline
FRC #3999
tanguma26 is an unknown quantity at this point
Hey we are team 647 and we are trying to develop our own swerve drive and I was wondering if you can post some examples of your program we are having some troble with our program and we are using Lab View.
Thank You
Unread 22-05-2010, 12:49
kgzak's Avatar
AKA: Kris
Thank You
I can post some examples. I will post them later right now I am at my friends house and don't have the ability to do so.
Baisically what my code does is it compares two numbers and if the pos_in(position the feedback tells you you are in) is greater than pos_to(Position to go to) then it sets the speed to -1 and 1 if it is the other way around. I also have a lot of safeties built in such as: If the feedback isn't counting, if it is turning the wrong way, etc. You may have a few questions because I really haven't commented any of it and it even confused my dad at first, so I will be willing to answer any other questions you have.
Unread 23-05-2010, 00:03
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
a simpler way to do this exists.
it's called proportional control. p from pid.
Basically, you say;
Code:
error = setpoint - process_variable
output = error * Kp
And Kp (gain) is constant. Nice and easy. You should only need a safety at the left/right boundaries to cut off the output when it gets out of range, and possibly some functions to invert motor and rotate inverse. You tune the gain so that it goes as fast as it can without oscillating.
Edit: Forgot to talk about I and D:
Integral (I):
Basically you integrate the error and add it to the output:
Code:
integral += error
output += integral * kI
Ki is Integral Gain. You also need to reset integral to prevent integral windup. Generally you do not need to implement I unless you cannot get enough accuracy with P alone.
Derivative (D):
You calculate the derivative of the previous action to determine how momentum will affect the stopping ability. Basically, it works against P and I to slow it down when it nears the end, allowing a higher P gain. You will almost certainly not need this with crab steering, as the friction of turning the pods will probably slow their rotation very quickly (D would be useful for, say, a 6' arm that has a lot of mass at the end).
Kettering Motorsports
Mecanum or Swerve? buildmaster5000 Technical Discussion 73 18-04-2010 11:19
Programming Mecanum Zrob Java 22 04-04-2010 23:00
Mecanum Programming Help Mars Programming 8 27-02-2008 15:41
mecanum programming mrmummert Programming 27 28-01-2007 13:45
Need help programming our swerve with feedback? activemx Programming 25 13-04-2004 07:29
