Go to Post Teams rarely win FIRST events because they can complete actions that nobody else can; they win because they do things faster than others. - Madison [more]
Unread 19-04-2010, 18:36
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Picking a gyro for field-centric swerve control
In 2009, we created a field-centric turret system that let the gunner push the joystick in the direction he wanted the turret to face, no matter what direction the robot was pointing in. The only issue we had with the system was a hard impact would knock the gyro angle off.
In the off season, we've planning on developing a swerve drive, and I'd like to set the controls up the same way. As a result, I already know one of my primary controls problems is going to be how to keep that gyro from jumping out of alignment.
Now, I'm a mechanical guy pressed into work as a controls guy, so I haven't dealt with much of the high level control stuff. I'm sure other teams have dealt with this same issue, but I'll start by breaking it down into possible solutions:
1. First, you could try to use some other system to double check and remove the error. Wheel angle / distance encoders doing dead reckoning would be my first thought, but because the absolute angle of the wheels to the field would be dependent on the gyro they would quickly build up error and not a be a good source of correlation.
2. You could try to sense out-of-bounds conditions and simply ignore them. You could remove changes that exceed the spin-rate of the gyro, or any other odd fluctuations by putting a series of case-statement checks inline that create a correction factor.
3. You could continue to try to improve the gyro itself. I see that sparkfun now sells 1500 degree/second gyros. While I haven't dug into their specs to check if their resolution and drift is still suitable, it seems like you'll reach a point where you simply don't have the issue anymore.
4. A hyrbid of 1: completely remove the gyro from the robot and do angle dead-reckoning using only the absolute wheel angle encoders and transmission encoders.
Has anyone else found a solution to this issue?
pic: DS Swerve on the field Racer26 Extra Discussion 15 09-04-2010 21:34
Steering control without a gyro nathanww C/C++ 4 27-01-2009 12:14
Crab / Swerve drive joystick control scheme Tom Line Programming 12 16-04-2007 18:47
Swerve drive control system dpick1055 Programming 8 22-01-2007 19:06
Omni-wheels and driver-centric drive efoote868 Programming 10 01-11-2006 22:22
