Go to Post Ohh the [strike]humanity[/strike] robotity! - artdutra04 [more]
Unread 20-04-2010, 14:33
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Picking a gyro for field-centric swerve control
Originally Posted by Golto View Post
What about using a compass. Wouldn't this give absolute position, without the need for gyros? Sure, they're a little more expensive, but their accuracy would be much more than that of a gyroscope.
This little 1 deg compass is sure affordable. http://www.sparkfun.com/commerce/pro...oducts_id=7915. Not sure what the output 2.5 deg rms error spectral characteristics are like.
In the short term, the fine gyro could beat this for accuracy given a good initial alignment... but that's tough to do in FRC competitions.
Edit:
Alex:Others have reported (and it makes a lot of sense) that the compass modules they've used are very sensitive to the "natural" EMI environment around the permanent magnet motors in our bots. My own limited experience with such modules outside of a FRC environment matches their observations, so I don't have a high degree of confidence in that approach.
I too have not used a compass on an FRC and had this concern. I would guess the EMI noise would be amenable to low pass filtering and used for longer term automatic updating of the integrated rate. But again, we have introduced a two sensor complexity.
pic: DS Swerve on the field Racer26 Extra Discussion 15 09-04-2010 21:34
Steering control without a gyro nathanww C/C++ 4 27-01-2009 12:14
Crab / Swerve drive joystick control scheme Tom Line Programming 12 16-04-2007 18:47
Swerve drive control system dpick1055 Programming 8 22-01-2007 19:06
Omni-wheels and driver-centric drive efoote868 Programming 10 01-11-2006 22:22
