Go to Post I like my eyeballs where they are ::safety:: - ,4lex S. [more]
Unread 20-04-2010, 09:40
DinerKid's Avatar
DinerKid DinerKid is offline
AKA: Zac
FRC #1768 (Nashoba Robotics)
DinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of light
Crab/Swerve Drive Module Attachment Point
I have been getting really into crab drive since just a little while before championships. I was pumped to get to see so many awesome crab drive modules in Atlanta, many using bevel gears and a hollow shaft so the modules can spin as many times as they want. One question that i still have is quite possibly the biggest thing to overcome in making a crab drive chassis. How do you attach the module to the frame such that it is strong (will not have much play especially in a pushing match) and able to rotate.
Looking at the 221 revolution module i see what appears to be a thrust bearing but it is still confusing. Is it expected that you will slide the 1.5" Coupler piece into a hole drilled in the frame and attach it with a collar? That is what it seems to me from reading the description.
If you have a picture of a module attached to the frame that would certainly be very helpful
Thanks
~DK
Unread 20-04-2010, 10:58
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: Crab/Swerve Drive Module Attachment Point
Team 228 should be posting their SolidWorks model very soon for this year's robot. Our mounting was to capture the swerve module surfaces between two 0.25" Delrin bearing plates mounted to the robot frame. It took quite a few man hours to get the bearing plates to run flawlessly, but it was worth it. This connection system worked very well for us this season with no failures.
The bearing surfaces had quite a large OD in anticipation of the cantilevered stress from climbing the bumps and playing heavy defense. On a flat playing field we'd probably go with a much smaller bearing surface.
We did not do full concentric swerve. There are measurable efficiency losses in using bevel gears which we didn't feel were offset by the ability to spin a drive pods continuously. Our swerve pods were fully independent allowing us to rotate while driving in a straight line (there's a white paper here on CD covering independent twisting swerve).
We used a three axis joystick and gyros for field-centric control. The third axis (joystick twist) allowed for the rotate while driving in any direction.
The swerve system had a pretty steep learning curve for us. I would definitely recommend prototyping during the off-season to avoid some of the stress that we encountered.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 20-04-2010, 11:09
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
The stock mounting solution for the Revolution swerve is exactly as you described. The outer most hub is intended to be clamp mounted to a plate or whatever surface you prefer.
The outer hub could also be removed and a series of bushings or bearings could be used to capture the module instead.
Rigid mounting is definitely a concern when developing swerve technology. Good luck
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 20-04-2010, 12:48
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
The 1986 swerve module is supported entirely from above the module by a vertical, hollow steel pivot stem mounted in bronze bushings. It has often been stated as a given that in order to handle the sideloads seen in a traditional game on carpet a swerve module must have lower support. We have proven that is not necessarily true. Our welded steel pivot stem saw brutal punishment throughout 3 events, and is in perfect shape.
Unread 20-04-2010, 12:49
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Our drawings are online, look at the 4 Wheel Pivot Drive page. There are links showing how the pivots are built and attached to the robot. You can see how the mounting plates hold the bearings and how the entire assembly is kept together.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 20-04-2010, 12:53
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
+1. Lower support is not required, as long as you build it right. DSSwerve had no lower support this year.
PS. Dont know what DSSwerve is? Search it.
Crab/Swerve Drive wheel rotation issues DavidGitz FRC Control System 5 30-01-2010 10:25
Questions about crab/swerve drive. BenX02 Technical Discussion 62 28-04-2009 20:38
Crab / Swerve drive joystick control scheme Tom Line Programming 12 16-04-2007 18:47
Inexpensive crab module? Jeremiah Johnson Technical Discussion 20 24-04-2006 17:10
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
