Re: Most Goals Scored in Autonomous?
In the semi finals match between 469, 1114, and 2041 vs the Poofs, Comets, and us, we scored 5 of the 6 balls. I can't remember if 3357 had an autonomous of not, but I don't think they did, which means all 5 were scored from midfield and downtown.
I've seen matches where all 12 balls hit the chains, but I think you'd have to do that 100 times to get one match where all 12 go in.
You could calibrate a kicker to aim below the chains... Maybe if 1986 had a 5 auto and any random team had a single low auto, there would be a 6 score.
Our low trajectory was indeed a big part of our frequent success in auto, but left a small margin for error in kicking strength. Unfortunately, our relatively slow bump crossing did not allow time for >3 auto.
Would have been nice to, uh, you know, see the whole field do autonomous, but that's my pet peeve.
This is a good example to point out that the "official" screen video is a record of what happens on the field, not for artful closeup shots. Here it is, only a few weeks after the fact and we have no idea who or how those nine points were scored. Before I looked at the video, I wondered -- did a single robot kick six balls? Or maybe six robots kick nine? Now I am still wondering. No record to show it. Sorry for getting on my soapbox, David. It's not your fault. I really would have liked to see how it was done. ~~~~~ To end on a more positive note, to kick a ball was a simple autonomous task, yet did take a lot of work to pull off. The robots that were able to kick three balls in the far zone, jump the bump, and kick two more were great. |
In the LA finals match #1 video, at least the scoring graphic was shown. At the end of autonomous the score was 5-4, in favor of the red alliance. In the match, every ball was kicked by robots in the far- and mid-zones, with near-zone robots "cleaning-up" by driving into the goals after a 10-second pause. |
I remember that we (2415) had a match at the quals for Newton that managed to score five balls in auto (one in front, two in middle, two from the back). We would have had six, but the third ball from the back just barely clipped our back bumper! D'oh!
I've expressed this before, but what is worse is when your team tells you thats its usually the last thing taken care of..... Makes me really sad ![]() I'm sorry but without the Autonomous In my oppion (I know this is not Dictionary Definition) it is just once big RC car. Sorry for also being on the Soap Box but this just really gets to me. |
#10
For example, this year's robot had a three-speed DeWalt transmission on the arm, and a servo to shift it from first to second gear to deploy faster. At the operator's request to deploy, it would move over until the shift point, shift into first, and use a separate set of gains with the different gear ratio. As the operator grabbed the pole, they would press a button to lift the robot, and it would lift. If the latch was not latched, they could deploy again, and it would stay in first so as not to risk missing a shift under load. All of this was automated, as the operator has a multi-position switch with each mode (start, vertical, deploy, and flip). Another, possibly better example: 33 in 2007. 3-axis arm, with two joints on the same plane. The operator had a box for each position as well as a joystick. They would press the, for example, Floor button and it would recall the position and go to it. This is simple. However, as the operator pressed the, for example, Score Mid button, the robot would then: 1. recall the position and set that as setpoint of each joint 2. Calculate the error on the first joint and use the second joint to correct for that error, so the end-effector is at the same height 3. Allow the operator to use the Y axis of their joystick to slide the end-effector in and out at the same height, while changing the shoulder and elbow positions automatically. This allowed some wiggle room for the driver to be closer to or farther from the rack then expected, or there was a robot in their way (just score over them). 4. Calculating the position of the mass (claw) and adjusted the D term of the shoulder based on the horizontal distance from the joint, to prevent it from speeding up and overshooting as the distance (and torque on the joint) decreased. 5. The claw was very wide, to control the tube, so when the claw was pulled into the robot, it would automatically slow down or wait for the claw to rotate to a position that would not hit the ifself before bringing it into the machine. 6. The claw was also asymetrical to allow easier collection from the floor, and the top jaw would close 1/10th of a second before the bottom jaw. Some more robots. 33 in 2008. This robot had a two-speed AndyMark transmission, geared for 14fps high. It generally looped the track at high speed with the trackball, then slowed down a little to lift it over the overpass, etc. This robot had a semi-automatic transmission. If the driver was in low, flooring it, and the robot was moving at its top speed in low gear, for long enough time, it would assume that the driver is racing and shift up. In a real scenario, the driver could have shifted to low to push an obstacle (defensive robot?) out of the way, then broken through and continued on, and the robot would return to high gear for racing. Several robots have had this, this is the one I know the most about. Another robot. 33 in 2001. Back in the day of the PBASIC processor with 63 bytes of variable space. The robot had an inclinometer, a weight attached to a potentiometer, and with the push of a button it would very quickly level itself on the ramp. Much faster than an operator could've done it. (the points in that game were based partially on time it took for you to complete the match; you could end the match early to gain bonus points) Many FIRST robots have advanced past the remote-control car stage. They now use automation to help lower the load on the drivers and operators, so they can focus on playing the game instead of translating commands into what the robot wants. A great thing that many teams tried to do in this game was use the target to align to the goal. Autonomy in teleop, although many of them found that vision processing ate up so much CPU it caused problems with PID controls. Back to this year's autonomous modes, 33 could kick five balls. We focused on tuning the first three kicks, and by Nationals, at least two of three went in (providing the drivers lined the robot up, something they weren't very good at). The last two were more tricky, because the robot's alignment would change when it went over the bump, but it usually made one of those as well. We had closed-loop control of speed per side and triggers on distance, but did not use the camera to line up any shots. @GDC: A longer autonomous period could create a greater incentive to write one. 20 or 30 seconds of full autonomy would make me very, very happy. |
#11
If I remember, in the Archimedes finals, we (33, 148, 201) scored 5 out of 6 balls, while 254, 233 and 3357 scored 3. (I think 33 scored 3, we, 201, scored 1, and the second hit the chains and came back out, and then 148 scored 1).
| 3 scored in Autonomous by a single bot!!! | MamaSpoldi | General Forum | 19 | 15-03-2010 14:33 |
| Don't count goals scored for the opposition - Yes or No? | Travis Hoffman | Rules/Strategy | 40 | 09-03-2010 18:07 |
| Most Keepers scored in a single match | The Lucas | Championship Event | 19 | 20-04-2007 16:22 |
| Most Ringers scored on the Rack in a match | Jonathan Norris | General Forum | 18 | 15-04-2007 23:32 |
| Scoring Corner Goals During Autonomous | CronosPrime1 | Programming | 18 | 22-01-2006 18:04 |
