Go to Post People... chill. It is week 1. Recall week 1 last year when many teams said "no one is capping with the 2x ball"... "only a few teams are hanging". - Andy Baker [more]
Unread 22-04-2010, 17:03
Jstack14 Jstack14 is offline
Team Role: CAD
Rookie Year: 2010
Jstack14 is infamous around these parts
Tank Tread Help
We are in need of some help...
We are making a robot that is about 3.5 ft. by 2 ft. wide. We are going to put some sort of tank tread on it but what we currently are using is not working. Currently our tread is two lines of chain that go around two sprockets each. They are connected with strips of Lexan that are riveted into the chain every fourth link. On the sprockets every fourth link is cut off so that the rivet pieces of Lexan line up with the cut out teeth on the sprocket. This system would work, but all of the holes on the Lexan pieces don’t line up, so the chain slips off often and then it simply doesn’t work. We are wondering if anyone has suggestions how to fix this, because if we can’t fix it we will have to come up with a new idea. We are thinking timing belts and pulleys, but we can’t find any that are wide enough. Does anyone have any suggestions on how wide the belt would have to be to be effective, and where we could find a fairly affordable belt that size?
Or are we approaching this entirely wrong?
Unread 22-04-2010, 17:12
viperred396's Avatar
viperred396 viperred396 is offline
people have lives during January?!?
AKA: Bryan
FRC #2240 (Brute Force)
Team Role: Leadership
viperred396 has a spectacular aura aboutviperred396 has a spectacular aura aboutviperred396 has a spectacular aura about
Re: Tank Tread Help
we used timing belts for our robot this year. We bought them at http://www.brecoflex.com/ With them you can get custom treads at any size
2010 CO Regional: Finalist
2007 CO Regional: Semi-Finalist
Unread 22-04-2010, 17:14
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: Tank Tread Help
I couldn't quite follow the description of what you are doing. Is it possible to post a pic?
Unread 22-04-2010, 18:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Tank Tread Help
Also could you tell us what "affordable" is? Under $100? Under $1000? Under $10,000?
Unread 22-04-2010, 19:06
commodoredl commodoredl is online now
AKA: Dan Lavoie
FRC #2877 (LigerBots)
Rookie Year: 2007
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
Re: Tank Tread Help
This year our Breakaway robot used a tank tread drive system. In order to save money, we designed it to use triple-wide drive chain run on two sprockets, rather than buying belts from Brecoflex. I think the chain was available through some surplus store; I don't know where we bought it. This worked out well for us since the chain was wide enough that we could use it as a track and it never slipped in competition. To make it legal, we attached small pieces of hose using bolts, as you can see in this picture.
Technical Mentor
Team 2877 - Ligerbots
2016-
Previously:
Team 578 - Red Raider Robotics
2007-2014
Unread 22-04-2010, 19:09
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Tank Tread Help
Check out the local tractor supply store, you might find something that will suite your needs. In Oklahoma there was a team (i think it was 2824) that used some treads from a tractor supply equivalent and they never threw a belt and had crazy pushing ability. The treads I am thinking of were about 6 inches wide.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 22-04-2010, 19:11
Team Role: CAD
Rookie Year: 2010
Re: Tank Tread Help
I am waiting for the pictures to be approved or whatever so I can give you the link on Chief Delphi. Also for the price question under a thousand is a must, and honestly under 500 would be ideal. The cheaper the better because we already have invested a decent amount of money into the system we have which is not really working, and we don’t have a large budget to work with.
Unread 22-04-2010, 20:38
Nevets Amstier's Avatar
Nevets Amstier Nevets Amstier is offline
Dont Hesitate
AKA: read my username backwards
FRC #0155 (Technonuts)
Nevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to all
Re: Tank Tread Help
I recommend buying a pulley/belt system from a company called "Polytech", our team was EXTREMELY unsatisfied with our Brecoflex belts. Not only were they delivered way behind schedule, but also they snapped after only 3 or 4 matches, whereas the comparable polytech belts lasted an entire regional (12-14 matches) and an entire day of practice on our own field.
http://www.polytechdesign.com/
anyway,
I liked 578's style of afordable belts, they worked well at FLR where we competed against/with them.
CLAKSON UNIVERSITY CLASS OF 2011
2012-?: Technonuts team 1552008-2011: Division By Zero team 229
2006-2007:Bobcat Robotics 177
Unread 22-04-2010, 21:38
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
Re: Tank Tread Help
on this year's winning NASA Lunar excavation robot, there were these tracks.
Thy consisted of aluminum C-stock fastened to chain that had special links that allowed things to be attached to them without modifying the sprockets. you can find them here: http://www.mcmaster.com/#roller-chain/=6s0umt Scroll down to the bottom and click on accessories. Unfortunately, they're only available for 35 pitch chain.
EDIT: Here's a pic of the link.
Unread 22-04-2010, 22:51
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: Tank Tread Help
I've never done this before, but I would suggest timing belt since it requires fewer modifications than chain, and has fewer moving parts and joints. also, I would check to make sure the chain/belt is tensioned properly and hasn't stretched.
Unread 23-04-2010, 11:17
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
Re: Tank Tread Help
Handmade..cheap...and the best treads i've seen. http://www.maikenmagic.com/?ref=show...20Build&num=23
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 23-04-2010, 11:18
Re: Tank Tread Help
here's an innerworking picture http://www.maikenmagic.com/?ref=show...20Build&num=11
John Fogarty
Unread 23-04-2010, 12:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Tank Tread Help
May I first ask why you think you need tank tracks/treads?
Unread 23-04-2010, 12:08
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Tank Tread Help
The simple and cheap solution may be to go with a higher pitch chain. I would think #35 at the smallest, but even higher may be necessary so the teeth of the sprockets have more chain to dig into as the whole assembly rotates.
I'd also recommend you fix the "holes don't line up" issue. It sounds like you have many lexan pieces and they all need to be identical. A jig, automated process, or assembly line may be in order. Look for defects as they come out of cutting/drilling and discard any grossly imperfect pieces.
GitHub
  #15   Spotlight this post!
Unread 24-04-2010, 11:01
Team Role: CAD
Rookie Year: 2010
Re: Tank Tread Help
Well honestly i do not think we need tank treads, however our team is set on tank treads.
Tank tread chs1368 Technical Discussion 27 07-01-2007 15:54
tank tread inventor file SgtMillhouse648 FIRST Tech Challenge 0 14-09-2006 11:12
Tank Tread Wheel Joe_Widen Technical Discussion 8 29-05-2006 23:28
Tank Tread suppliers? Rombus Technical Discussion 2 22-02-2005 11:01
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
