Go to Post It's not about taking risks, but more about identifying them (which is the hardest part) and reducing them. - Deke [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 20-01-2012, 14:40
imjessica's Avatar
imjessica imjessica is offline
AKA: Jessica
FRC #4159 (CardinalBotics)
Team Role: Electrical
Rookie Year: 2011
imjessica is a jewel in the roughimjessica is a jewel in the roughimjessica is a jewel in the rough
Re: Electrical Board Mounting
Hey everyone! more pictures of circuits would be really, really helpful. The older pictures have different pd boards and batteries. If someone could also have some closeups of certain connections (like the wires connected to the pd board or the jaguar) that would be VERY helpful. I cant figure out with the outlets on the jaguar are called. thanks so much!!
SF CardinalBotics - Head of Electronics
  #32   Spotlight this post!
Unread 20-01-2012, 15:25
GiannaRae23 GiannaRae23 is offline
AKA: Gianna
FRC #3567 (The Aviators)
Team Role: Leadership
Rookie Year: 2011
GiannaRae23 is an unknown quantity at this point
We mounted ours on a board last year. Yes, like a wood board. No, it didn't catch on fire. Haha. We used zip ties to keep the wires organized and a label maker with a flag function to label each bunch of wires appropriately. It was a life saver when things needed changed...Also, our cRIO was held in place with velcro...that stuff is your friend. If I find any pictures of ours from last year, I'll be sure to post them. Hope this helped!
  #33   Spotlight this post!
Unread 20-01-2012, 18:11
imjessica's Avatar
AKA: Jessica
Rookie Year: 2011
yes that would be helpful! did you use two layers? im not sure we have the same type of board but ours in kinda thin im afraid it wont support the weight
also, did you mount the battery on the board? its super heavy I wanted to mount it on the side of our robot but im afraid thatll unbalance it
  #34   Spotlight this post!
Unread 20-01-2012, 18:37
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Last year, our electrical board and our battery weighed about the same. Mounting one on one side and one on the other balanced things out nicely.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
  #35   Spotlight this post!
Unread 23-01-2012, 07:27
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Jess,
If you look close at the Jaguar in the area of the screws, you will see one side has molded into the case V+ and V- while the other side is M+ and M-. The M screws are the motor side and V screws are the side you wire to the PD.
Al
WB9UVJ
www.wildstang.org
________________________
  #36   Spotlight this post!
Unread 23-01-2012, 07:52
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
cgmv123 (Max): I like the idea of balancing the battery on one side against the power board on the other, but did that make for a pretty long run of 6 gauge from the battery on one side to the power distribution panel on the other?
  #37   Spotlight this post!
Unread 23-01-2012, 09:41
cgmv123's Avatar
AKA: Max Vrany
Rookie Year: 2011
No, the standard run length worked just fine. You can see it here:
and here:
It wasn't that much of a stretch, and it worked well.
  #38   Spotlight this post!
Unread 27-01-2012, 08:33
fovea1959's Avatar
AKA: Doug Wegscheid
Rookie Year: 2011
We're going to have a short/wide robot, so I'll have an extra 10" of chassis width, which is at least an extra 10" of 6 AWG from the battery on one side to the PDB on the other. Is this extra length significant? It's not optimal, but compromises must be made....
if so, trying to figure out which is worse: asymmetry, or high CG. sidepod mounted battery will end up being 12-18" from the floor. I think I can find a spot lower in the middle, but then I have all the electronics on one side, and no battery on the other to counterbalance it.
Anyone got any experience with battery up that high?
Anyone got experience with that level of asymmetry?
Short wiring runs, weight symmetry, low CG. Pick 2... perhaps only 1.
(wish I had good pics of 2612's robot from last year; they did the side mount electronics last year, and it was gorgeous)
  #39   Spotlight this post!
Unread 27-01-2012, 08:40
Unsung FIRST Hero
Rookie Year: 1996
As a rule of thumb, #6 wire will drop 0.1 volt for every two feet of wire length at 100 amps. Stall current on a CIM motor is 133 amps. Four CIMs at near stall will drop roughly 0.4-0.5 volts every two feet. Remember that the black wire and red wire both carry that current and the total length is included in that calculation.
At 12 pounds, the battery is a good way to manipulate COG. I always recommend that teams keep the battery low, inside the robot, to help prevent tipping.
In the order of things, COG first, short wire runs second. Symmetry can be compensated in other ways. If you tip over or can't maneuver, having good electricals won't do any good.
Al
WB9UVJ
www.wildstang.org
  #40   Spotlight this post!
Unread 27-01-2012, 08:54
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Al's advice is first rate. And one should tie everything down (note my handle ;o)). The robot is a high vibration environment and you do not want the wires moving near their attachment points (or at all). When I deliver racks of equipment to the Navy, they check for wire bundles to be tied down every 6" and at every point a wire enters or exits the bundle. Plus a clean wiring effort reduces the chance that a wire gets caught in a moving mechanism.
Labels are a big help! It makes diagnosing/repair/replacing things in the pits much easier. Label the wires, the motor controllers, the spikes and other actuators.
It is a good idea to minimize the length of power wires to/from motor controllers but note that this is really an effort to minimize the total length from PD to jag/victor plus jag/victor to the motor. The jag/victor can go anywhere along that length with little penalty (length of PWM or CAN cables).
Work hard to minimize the 6 AWG wire lengths!
HTH
  #41   Spotlight this post!
Unread 27-01-2012, 23:28
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
My team is using industrial strength velcro and honeycomb structure plastic.
Team 1369
Senior
Head Programmer (Java)
Head Electrician
  #42   Spotlight this post!
Unread 27-01-2012, 23:38
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Looks like this would be the thread to post this question into:
With the addition of the barrier this year, anyone have a shockmounting idea for the electronics board? We usually put the cRio on rubber material to absorb minor impacts, but this year looks like a more heavy duty mount is in order. We were thinking something like surgical tubing standoffs. Modeling it off the rubber standoffs of the pre-2011 compressor. (That big grey paperweight.)
Suggestions?
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
  #43   Spotlight this post!
Unread 27-01-2012, 23:39
Lightfoot26's Avatar
Lightfoot26 Lightfoot26 is offline
Just Out For A Rip, Bud...
AKA: Seth Lightfoot
FRC #1625 (Winnovation)
Rookie Year: 2010
Lightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really nice
Not gonna lie, I wanna marry the person over at #254 who does their wiring... I have admired it for years. just sayin'
Winnovation Team 1625 (2010-??)
  • Electrical/Programming Captain (2011-2013)
  • Auxiliary Driver (2012-2013)
  • Team Captain (2013)
  • Alumni (Graduated May 2013)
  • Electrical and Programming Mentor (2014-??)
  #44   Spotlight this post!
Unread 28-01-2012, 00:32
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I wouldn't worry about the cRIO. It's very rugged. I worry mostly about what's connected to the modules, and make sure everything is securely tightened down.
  #45   Spotlight this post!
Unread 28-01-2012, 07:20
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Or the modules themselves...
In 2010, our cRio was mounted horizontally (with the modules facing the rear of the robot), and we managed to eject our whole analog module going over the bump. No damage to the cRio, but the analog module was no longer attached.
We promptly glued the modules in with silicone, and now we always secure the module clips with clear duct tape.
Kettering Motorsports
2898 electrical board FlyingHedgeHog Electrical 13 03-02-2010 14:59
Mounting on the Control Board seanl General Forum 3 06-03-2009 20:46
Mounting the IR board Aratznes_Scythe Electrical 4 18-02-2008 02:07
Pneumatics Board/Mounting Components ASmith1675 Pneumatics 2 06-02-2008 13:47
Mounting Electrical Parts SpaceOsc Rules/Strategy 21 15-10-2004 22:52
