Go to Post My sister's husband told me when I was just a wee one, "momentum will take you where traction will not." - Joe Johnson [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations > The Blue Alliance
Unread 25-04-2010, 14:57
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
[TBA]: Automated match parsing
As suggested by Greg Marra, this thread is to discuss a system to automatically parse matches.
I had initially suggested using the match audio to detect the beginning and end of the matches. The reason for this is that the audio is always available, and the audio markers are well-known. Also, the audio has a much low data rate than the video, which theoretically means that it requires less processing. I happen to be taking a class in digital signal processing, so I have a couple ideas of how to actually implement this.
On the other hand, Greg has mentioned a LabVIEW VI in the works which is able to work based on the match progress bar on the bottom of the screen. There is less noise in the video, so it should be somewhat more reliable than audio. However, I have seen instances where the progress bar wasn't shown for the first few seconds of the match. Presumably, a video-based method could also parse the text on the bar and automatically grab the regional code and match number.
Obviously, if we could get some kind of feed from the FMS, that would be even better.
Thoughts or ideas?
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
[TBA]: Parsing Newton, Curie Greg Marra The Blue Alliance 9 20-04-2009 14:22
[TBA]: Parsing Hawaii Greg Marra Video Archives 5 22-04-2008 23:07
[TBA]: Parsing New Hampshire Footage Jonathan Norris Video Archives 9 05-03-2008 23:42
[TBA]: Live Match Updates Greg Marra The Blue Alliance 2 01-03-2008 13:39
Parsing usfirst Match Data Jack Scouting 0 08-03-2003 02:00
