Go to Post Joe is a great sport and this was a good moral booster after a grueling weekend. How many opportunities do you get to play William Tell with a Regional WFA Winner? :) - The Lucas [more]
Unread 25-04-2010, 20:16
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Off season battery
We have been invited to participate in a parade with our robot. However, we only have four working batteries. We will need at least one hours worth of battery. Can we replace the standard FRC battery with a car battery?
Unread 25-04-2010, 21:03
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Off season battery
You should be able to, as long as your robot can support the weight!
It will probably hold about 4 to 5 times as much energy as a single robot battery.
Unread 25-04-2010, 21:17
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
If you are planning on doing this on any kind of regular basis, however, you might want to consider a "deep cycle" battery rather than standard automotive battery.
Deep cycle batteries have a slightly different plate design so that they can be repeatedly discharged and recharged without damage.
Car batteries are designed for maximum current draw... short bursts of current to the starter motor and then recharged right away from the alternator.
You might find deep cycle batteries listed as RV or Marine batteries.
But if you're only doing it once... you should be fine. And if you don't discharge the car battery all the way, you should be better than fine.
Keep in mind, of course, that your "robot" batteries are SEALED lead acid batteries... they don't leak when you tip them over. Car batteries like to be kept upright... so you might not want to do too much bump climbing during the parade.
Jason
Unread 26-04-2010, 08:02
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
G,
Automotive batteries are rated in the 50- 55 Amp Hour class, about three times the capacity of our robot battery. I would recommend stripping off things that you won't need in the parade like a ball handler and tower climber to lessen the weight. In most cases your battery drain will be fairly low as you will not be pushing, turning or climbing. Please be sure to fully insulate the battery terminals, these batteries can supply over one thousand amps in a dead short. Insulated battery clamps/terminals can be purchased where you buy the battery or from McMaster. I would also recommend one with an attached handle so that it is easy to carry around. If you are going to be kicking balls, be sure to check for loose hardware often along the parade route. You don't want to be launching parts into the crowd. Good Luck with the demo.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 26-04-2010, 08:13
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Rookie Year: 2007
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Alternatively, you can run 2 or more of your FRC batteries in parallel to achieve the longevity you're looking for.
Unread 26-04-2010, 08:21
Unsung FIRST Hero
Rookie Year: 1996
Ryan,
This is not recommended practice. When batteries are used in parallel they need to be nearly identical in operation. (MK and Battery Institute experts agree that same age, same lot, same charge/discharge cycles must be maintained for parallel operation) Used FRC batteries have gone through enough charge/discharge cycles that they are as likely to self discharge each other as they are to increase amp hour capacity. Diodes can be used to prevent this and are available at RV stores.
Al
WB9UVJ
www.wildstang.org
Unread 26-04-2010, 08:43
Thermal's Avatar
Drive Team Coach
AKA: Ryan Brown
Rookie Year: 2007
Originally Posted by Al Skierkiewicz View Post
Ryan,
Well consider me corrected then. Good information to know, thank you.
Post-Season Battery Storage Practices TennBikeBerk Electrical 10 29-04-2007 08:28
437 Showing Off it's Off Season NextPerception Robot Showcase 7 06-02-2007 19:03
running bot off car battery? Trashed20 Electrical 25 06-06-2003 12:57
running the OI off a battery AlbertW Electrical 25 29-04-2003 13:09
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
