Go to Post Who has time for boredom? - Dr Theta [more]
Unread 27-04-2010, 13:40
Carolyn_Grace's Avatar
Carolyn_Grace Carolyn_Grace is offline
Build bridges not walls.
AKA: Carolyn Beyer
FRC #1024
Carolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond repute
Re: List of Killer Bee Bot Bottoms
Originally Posted by Gary Dillard View Post
I think in the division finals you had something like "On to Einstein" in the the first match, and then in the second match (after losing the first match) it was "On to Einstein?"
It just said, "Einstein?" during the division finals. We were being hopeful. hehe
We didn't change the signs inbetween matches of each round of the eliminations, as we didn't want to take away time from Pit Crew's much needed robot assessments.
"It is change, continuing change, inevitable change, that is the dominant factor in society today. No sensible decision can be made any longer without taking into account not only the world as it is, but the world as it will be." -Isaac Asimov
Unread 27-04-2010, 14:05
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
I found an error in your code, let's debug:
If (33=Team) WIN();
In this setting, 33 is your variable (assuming you defined it earlier). Let's assume 33 is currently set to null. In your example above, you are saying "If set 33 to Team then call Win" However Team is not a valid variable, instead it should be 'Team'. So that would kill you first. THEN you are setting 33 to Team, I think you would rather do a Binary test now wouldn't you? You would rather it be "If 33 is Team then call Win" which would require double =. So for this statement to function properly, you should have wrote:
If (33 == 'Team') WIN();
I win! XD
Unread 27-04-2010, 18:36
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
I disagree. == is not =.
= sets one variable to another. == checks for a comparison. so I am checking that team is equal to 33, if it is, then win. The order does not matter.
Actually, in C (or C++), it is better to put the constant before the variable, in case you forget the second =, so the compiler will give you an error for setting a constant instead of getting some crazy error at runtime.
EDIT: I see that BJC forgot the second =. The actual one says "if (33==team) win();"
Kettering Motorsports
Unread 28-04-2010, 11:33
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Language dependent. For example, in one of the languages I use for "fun" development checking for equality between numbers is done with the syntax: (= 33 Team).
But Andrew does make a good point, writing it Constant == variable is a great way of making the compiler check for your typos in C/C++. Why do more work when you can make a computer do it for ya?
33, will there bee more unique ones for offseason events?
Unread 28-04-2010, 20:51
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
I'm sure there will be!
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 29-04-2010, 09:01
Schnabel's Avatar
AKA: Eric Schnabel
FRC #0469
JAVA developer here. That's actually the point I was trying to make, you need the == to compare. I've never played with C or C++, so I have no clue yet.
I win! XD
Unread 27-04-2010, 19:24
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Yes, I remember coming over to your mini-pit at Troy during elims, wondering if you were needing a time-out, only to see the robot was upended to tape on a new sign.
(since 2004)
Unread 27-04-2010, 11:56
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Originally Posted by hektormagee View Post
We at Team RUSH like to keep everyone on their feet and having fun It's nice for us scouters, too, as we get to stretch our legs. Remember Dave's way of shaking his thing? I laughed so hard. Glad people enjoy our cheers Now we need to get the rest of the championship teams to do the cheer with us!
Dave, the judges, and the other volunteers had the best ways to shake their things. It's always great to the volunteers spirited and dancing!
I loved the signs. I wish the video crews had showed them at the end of all of the matches (they did for a lot of them, but not all)
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 27-04-2010, 22:42
delsaner's Avatar
delsaner delsaner is offline
With Upmost Efficiency
AKA: Eric DelSanto
FRC #1676 (Pascack Pioneers)
Rookie Year: 2007
delsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant future
Originally Posted by BJC View Post
It's a Michigan thing
Originally Posted by Basel A View Post
You haven't been to Michigan have you?
Oh how I would LOVE to volunteer at MSC. It appears that Michigan knows how to have some fun (and of course how to build good robots too).
We at Team RUSH like to keep everyone on their feet and having fun. It's nice for us scouters, too, as we get to stretch our legs. Remember Dave's way of shaking his thing? I laughed so hard. Glad people enjoy our cheers, Now we need to get the rest of the championship teams to do the cheer with us!
Hey Rush! Hey Pi! Hey Rush! Hey Pi!
"The creations of the hand are confined by reality. The creations of the mind know no such limits."
~MtG - Mind Unbound
Eric DelSanto
Game Announcer
H.E.R.E. Representative
Stevens Institute of Technology - Class of 2016 - BE/ME Mechanical Engineering
Concentration: Robotics, Mechatronics
[2008-2014]: FRC 1676 - The Pascack Pi-oneers
Unread 26-04-2010, 23:44
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
You can dance if you wana!
<pic of moon>
It is supposed to do that
Hey! - <pic of moon> - That's the one I (and perhaps a few other handsome, witty folks ) suggested.
True to my word, (Here) I am now grinning.
Do I win a tee shirt?
Blake
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Killer Bee Volunteer Recognition Award Jay TenBrink Thanks and/or Congrats 5 09-12-2006 22:41
National Spelling Bee on Prime Time Again, Why Not FIRST? skimoose Chit-Chat 4 31-05-2006 23:54
Killer Carts! Zzyzx General Forum 35 04-03-2006 15:38
Bumble Bee megacadet142 Math and Science 9 03-09-2004 15:44
