Go to Post Next year they should make Roombas the game piece. They're not very effective at vacuuming the rug that's for sure. - Koko Ed [more]
Unread 27-04-2010, 20:12
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
Rookie Year: 2007
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Question Creating a DriverStation using another PC?
I have been asked by another of our mentors to take an old PC we had lying around and configure it as another DriverStation (like the existing Classmate) to use with our prototype robot for off-season competitions.
I understand that the Classmate can be re-imaged using the "Restoration Key" provided in the KOP... however, I suspect this will not work on a different type of laptop as it would require different drivers, etc.
Is there anyone out there who has done this successfully? If so, then if you could give me the procedure you followed I would be very grateful.
Thanks.
Unread 27-04-2010, 20:15
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Creating a DriverStation using another PC?
You just need to install the latest Driver Station update to get the application on your PC.
That has everything you need.
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Do you need the Cypress board?
If not all you have to do is install the Driver's Station Update. When run on a computer without the DS software installed it will install it.
If you do need the Cypress software I'll let somebody else handle that as I don't have any experience with it.
EDIT: Edited to reflect the info from the posts below.
Unread 27-04-2010, 20:34
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Are you sure it doesn't install the cypress software? I remember specifically having to run the updater because of the re-install bug to get the cypress software running
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 27-04-2010, 20:39
Just Itinerant
DSUpdate1.1 includes the Cypress software.
Unread 28-04-2010, 09:34
MamaSpoldi's Avatar
Programming Mentor
AKA: Laura Spoldi
Rookie Year: 2007
Thanks for all your info. I don't need the Cypress board stuff, but I'm not sure that just installing the DriverStation Update works. Have you done this starting from a basically clean laptop?
I tried this (ie. just installing the DriverStation Update) and it would not run the entire dashboard application - it kept giving me error messages for missing files (related to NI, vision, etc). I took this to indicate that perhaps I needed to have LabView installed to get this all working??? I am planning on installing that, but before I went through that process and then found that it still had issues I figured I would ask if anyone had successfully completed the process.
Unread 28-04-2010, 09:41
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I have successfully run the driver station and dashboard on several computers with LabVIEW installed. I have not tried it without LabVIEW being installed.
Unread 28-04-2010, 09:49
Just Itinerant
I believe you do need the LabVIEW runtime support to use the Dashboard.
It's probably easiest to just install the full team version, so you can also change the Dashboard program later if you want to.
If you want to save room then it's about 30MB and available as a download from the NI site:
http://joule.ni.com/nidu/cds/view/p/id/1101/lang/en
Unread 28-04-2010, 10:36
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
I am not sure if just the Labview run-time will be enough. I was trying to install just the Driver Station update, and when I ran it, it was looking for some of the FRC vi's. I will try it tonight on the laptop I was working on and report back.
Note: I tried last night to load the Labview Run time software and the Driver Station update and it does not work The Driver Station requires some of the FRC specific vi's. (FRC_IO.vi). You need to install Labview along with the Driver Station update.
Unread 28-04-2010, 14:58
Simspi182's Avatar
Simspi182 Simspi182 is offline
AKA: Jordan Yamada
FRC #2090 (Buff n' Blue)
Team Role: Leadership
Simspi182 is an unknown quantity at this point
What I did was I found where the classmates DS app. was and put it on a flash drive and moved it over, but on the other computer it already had the latest version of labview
By the way this works.
N.B. I don't know where certain drivers are for certain controllers (i.e. for some reason only the classmate recognizes my Xbox 360 controller and the other computer doesn't)
Unread 29-04-2010, 09:21
MamaSpoldi's Avatar
Programming Mentor
AKA: Laura Spoldi
Rookie Year: 2007
Thanks to everyone for their help. I have now installed LabView (and updates) and the DS update... and it appears to work - although I have not had the chance to hook it up with the robot yet.
Unread 21-11-2010, 22:02
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
I downloaded the DS update onto another computer, but it only installed the cRIO Imaging Tool and the Setup Axis Camera program, no Driver Station. Is there another download that gives you the actual application that will run enable and disable the robot with the dashboard and all? The file I downloaded was from here: http://joule.ni.com/nidu/cds/view/p/lang/en/id/1535
Using driver station on another pc Philipose NI LabVIEW 3 04-03-2010 01:19
Driverstation Pong! byteit101 Programming 12 16-01-2010 16:31
Using another type of controler matthewfl Rules/Strategy 2 16-01-2010 13:50
driverstation outputs agough C/C++ 3 15-02-2009 22:25
Using another module to program the Vex CyberTroniX FIRST Tech Challenge 3 26-09-2005 13:13
