Re: Attempting the impossible
We did no chain last year and loved it!!
http://www.vandenrobotics.com/plogge...icture&id=1517 Those were Toughbox modules we made by adding a 1/2" hole in the corner of the toughbox for a dead shaft. Then mounted a gear directly on the wheel that meshed with a gear on the output shaft of the toughbox. Then used a pillowblock bearing on the opposite side of the wheel. This is a pretty straight forward direct gearing design, that most any team could do. Down side is using a gearbox for each wheel. This year we tried belts, but didn't use the right size and couldn't get the tension right, so we reverted back to #35 chain. The most common way chain comes off is misalignment and/or lack of correct tensioning. |
This year and last we've used Andymark Toughboxes (nano this year) direct-drive to the wheels. The Toughboxes stood up to the banging up and down the bumps this year with cantilevered wheels and NO signs of wear, though we only did 1 competition. It's slightly heavier than a typical drive train, but we really liked the idea of 4 direct-driven wheels when dealing with the bumps. |
timing belts=BAD IDEA! we tried that year, and we had to switch to chain in the middle of regional #1. they were hard to tension, and we even shredded a belt!
my advice is shaft drive or direct drive. or stay with chain. |
Timing belt AND chain have both been done to great success. They also have been done to great failure. Which it ends up being will depend on your implementation, attention to details, and design work. |
one of our mentors used to be on a wisconsin team (fondy fire). being from there, he told us something we should have followed: "team 93 once tried to use belts. there is a reason why they never have since." better yet, i found that someone from there said it here on CD on another thread: Quote:
reasons to ban the belt from your drivetrain; 1. belts have a lesser surface of contact. therefore, they skip and slip under less torque 2. related to #1, belts are harder to tension as belts stretch at a faster pace. 3. weight- belt sprockets are HEAVY. unless you have access to a CNC or a very precise mill and operator. if not, you will pay a weight penalty. 4. length- chain can be made shorter and longer, belts cannot. in the long run, it seems that belts are better in high speed, low torque situations. Chain is for lower speed higher torque situations. unless your wheels are <2" diameter, you can almost always count on high torque. and hence why belts never worked for us. Last edited by ratdude747 : 06-05-2010 at 20:20. |
as for belts, why use them if chain already works? its not broke, so don't fix it. |
Continuous improvement is one reason...
While you're correct, belts do require you to be more diligent in your design work, we found them to be slightly more efficient and lighter (using only manual tools) than an equivalent chain system. We also did the "Put it against the wall and drive forward and see what gives first" test. The Roughtop-Plaction wheels slipped against the carpet before the belts slipped on the pulleys. |
#11
Yes, alignment is critical and spacing cannot be adjusted without a new belt but this is what design is for. Also in the short time of driving a robot, a properly rated timing belt should not show any noticeable stretch. They definitely stretch exponentially less than 25 chain. I don't think any team should rule out a method of power transfer just because they dont want to put in the effort to properly design and spec the proper components. This year we had a 6 motor drivetrain geared at 9fps with 8 roughtop wheels. We used gates gt2 5mm pitch belt to connect all the wheels together and never once had a belt fail or even a belt that looked worn after 3 competitions. I will say that our set up wasn't even perfect and the belts still held up to the torque with no problem. For teams that dont want to take the time to design everything in CAD before hand and design in tensioning devices, sure use 35 chain and take the enormous weight penalty. We will happily be saving 5-10lbs with our timing belt drivetrain Last edited by sdcantrell56 : 07-05-2010 at 15:45. |
#12
We used chain on our mecanum system because we were afraid what the humps would do to direct-drive transmissions this year and wanted to displace some of that abuse through chain, and we also chained the mecanum wheels to raised traction wheels for hump-transversal assist...
We had no problems at FLR, but at Championship managed to shear -- that's right, I said shear -- four master links. On four separate chains. We think it was due to abuse on the Andymark pylons -- they were only aluminum, after all, and small deformations can pop things out of alignment. But shearing masterlinks, that was pretty impressive. We're not *sure* why, and the consistency of it happening on four separate chains is particularly confusing, but we're blaming aluminum abuse for now. (Perhaps a summer diagnostic project is in order.) A few years ago we went direct-drive off of AM 12:1 planetaries, and it held up very well in a very abusive competition. We'll consider it again, I can assure you. Last edited by pfreivald : 07-05-2010 at 08:22. |
#13
Impossible? I mean, I know AndyMark sells lots of stuff, but I didn't know they sold the Impossible as well!
In all seriousness, I think the Aztecs (157) did a timing belt drive in 2005. They may have continued doing them, but I haven't been to a regional with them since. Cyber Blue (234) did a great bit of research on belts vs. chains that you can find on CD-Media. Hope that helps! |
#14
#15
I thought that team 25 had at one time an all gear driven drive that was modular. It was very heavy but it was very effective. I could be wrong but it has been a year our two.
| Attempting the Bonus Round | bensherman | Rules/Strategy | 18 | 13-01-2010 15:49 |
| pic: Duece Attempting to Remove A Spoiler | IraJason | Extra Discussion | 11 | 04-04-2007 23:36 |
| Attempting to Cut BaneBot 56mm Shaft | edthegeek | Motors | 6 | 15-01-2007 08:51 |
| To Dream the Impossible Dream (Full Version) | Ken Leung | General Forum | 16 | 01-01-2007 12:41 |
| 568 making the impossible possible...kinda | Draqo | Control System | 6 | 24-03-2005 10:26 |
