Go to Post The only thing a team needs to survive is people who want it to survive. - Ryan Foley [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 30-04-2010, 01:00
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
Rookie Year: 2010
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
CANJaguar code with synchronization
Hi Gang,
I have a version of the CANJaguar code that does all of the control modes (position, speed, voltage and current) as well as adding the synchronization option to send messages to all of the Jaguars and then activate them all at once. Where should I send this code? I don't have commit privileges on FirstForge to add them to the repository.
I've also set the CANJaguar code up as a library that can simply be linked rather than included as source into your project. Anyone interested in the Makefile I wrote to create the library?
TIA,
Mike
Unread 30-04-2010, 06:40
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Rookie Year: 2000
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: CANJaguar code with synchronization
I would be very interested. Please email me! Good work!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 30-04-2010, 09:30
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Originally Posted by taichichuan View Post
Hi Gang,
TIA,
Mike
I believe the protocol is that you will be given control of a branch of the mainline project on FIRSTforge, and that will be merged to mainline after enough testing/consensus.
I'll poke the right people to make sure they look here, hopefully they'll contact you soon.
Unread 30-04-2010, 11:13
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Hi Gang,
TIA,
Mike
Hi Mike,
That's great work.
The easiest way to contribute at the moment is to create a tracker with the patch attached. I'll evaluate it and apply it. If there are minor things to change to match style or something, I'll do that as part of the merge, or if there is anything major, I'll ask you to make the changes and resubmit.
Thanks!
-Joe
Unread 04-05-2010, 21:03
OxfordRoboCats OxfordRoboCats is offline
FRC #2137
OxfordRoboCats is an unknown quantity at this point
We would be very interested in this, please send it to us as soon as possible!
Unread 06-05-2010, 13:23
Software Mentor
AKA: Mike Anderson
Rookie Year: 2010
I've posted the code as an attachment to the CANJaguar tracker at FirstForge.
http://firstforge.wpi.edu/sf/tracker...anjaguar_for_c
I hope it's of some use.
Regards,
Mike
CANJaguar vi's RoboGuy Programming 15 18-04-2010 02:23
Potential Issue with the C++ CANJaguar Implementation mattbutts C/C++ 2 19-02-2010 13:26
CAN, LabView, and Synchronization duane CAN 0 18-02-2010 19:36
Assigning synchronization groups? taichichuan CAN 0 16-02-2010 18:56
CANJaguar + BlackJagBridge plugin errors Shinigami2057 CAN 1 06-02-2010 11:20
