pic: 4 Inch Wheel Design
Re: pic: 4 Inch Wheel Design
Looks nice. Are you planning to broach the center with a hex or key? If so you might consider indexing the broach so that the "halves" broaches line up. This would allow the halves to be truly interchangeable.
Also, do you think you could get away with fewer spokes? -Rion |
Yes, i could but i liked the look of 10 versus 6 spokes for some reason. Yes since my upload i have added the hex broach and the halves line up perfectly. The purpose was to have the halves be interchangeable. Last edited by MWB : 01-05-2010 at 01:03. |
Nice Wheel,
How much does it weigh with bolts? -RC |
0.42lbs With bolts
0.36lbs Without bolts |
Is there any chance that you have the AM Shifter Gen 2 CADDED with the gear teeth? If you do can you send it to me?
Thanks RC |
My my that looks mighty familiar.
I too wonder about your plans for the bore, and the necessity for symmetrical halves. You might consider not having the bore extend through both halves. Timing/indexing a broach is a pain. Also, you may find it not worth it to have the wheel be two halves at all, if simplifying manufacturing is your goal. |
Nice! looks kinda familiar! Haha =)
![]() I see you're going "clamp style" for tread, but you need a little groove along your rim that captures the tread so it doesn't fall out (higher quality picture here where you can see the groove better http://604robotics.com/Blog/wp-conte...2/IMG_0296.jpg). I like how you made both halves symmetrical for ease of machining, however, what we do is make them asymmetrical so you can have a locating groove instead of using the screws/axle to center the two halves. Also, you might be able to get away with less spokes. 7 is a cool number. Keep up the great work! Last edited by Eugene Fang : 01-05-2010 at 01:12. |
#10
Ah,
I would try to aim for about ~.3 lbs. How thick and wide are those spokes? Quote:
-RC |
#12
Yeah I agree. As you can see from the pictures I posted, the back of our wheel is just a rim, which saves weight. It simplifies the broaching issue too. By the way, those 6" wheels I posted were 0.28 pounds each.
#13
Each half has a 1/8 spoke thickness and a 1/4 combined thickness. The spokes are 1/4 in wide each. Thanks again RC |
#14
WOW thats light!
#15
| pic: 4 inch Wheel Render | Chris is me | Extra Discussion | 25 | 15-05-2010 18:43 |
| 4 inch Wheel of Doom | R.C. | SolidWorks | 25 | 26-11-2008 23:57 |
| pic: 5 Inch Wheel | RMS11 | Extra Discussion | 24 | 18-08-2008 23:55 |
| pic: My wheel/leg design | mechanicalbrain | Extra Discussion | 17 | 07-10-2005 12:01 |
| 12 Inch Wheel Available in Several Formats | Ed Sparks | Inventor | 1 | 19-01-2004 07:12 |
