Go to Post Being professional means doing things right. Being gracious means doing the right thing. They complement each other perfectly. But I think we should remember to use GP as a guide for our own behavior, not as a yardstick to measure others' shortcomings. - Alan Anderson [more]
Unread 03-05-2010, 15:22
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Re: What does it take 6WD/8WD to be successful?
Originally Posted by dtengineering View Post
We've also found that using seperate control sticks for Forward/Reverse and Left/Right can help tracking. That way, when using "arcade" style driving (rather than tank style, where you control each side or the robot with a seperate stick) when you want to go straight forward you just lift your thumb off the "turning" stick, and you will always get a perfectly straight forward/reverse input to the robot. When you want to stay still and turn, you take your thumb off the forward/reverse, and all you get is turn.
Jason,
I'm looking for a little more detail on what you mean by this. I presume when you refer to "taking your thumb off" you're using a gamepad for driver control, rather than the traditional kit joysticks.
Most teams use the two kit-of-part joysticks to control the robot in "tank drive" style where only front/back on the sticks controls anything. In this way, the left stick controls front / back on the left side of the robot, and the right stick controls front / back on the right side.
The other common alternative is to have "arcade drive" where one stick controls the robot via front/back and right/left stick movements.
What I understand you to be suggesting is to instead use the two joysticks so that one of the joysticks controls front/back of the whole robot (like front/back in "arcade style") and the other joystick controls right/left turning (like right/left in "arcade style") but using 2 joysticks to provide this input rather than just one input. Am I correctly understanding what you are suggesting? Presumably, also rather than actually using two separate joysticks, you simply use a gamepad to provide the above control?
Our team has explored a lot of different drive approaches, but I don't think we've ever tried the above. Sounds like something our team should give a go during the off-season... Thanks for sharing!
--ken
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 06-05-2010, 08:30
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Originally Posted by TEE View Post
Basically what the title says... what does it take to make a great 6 or 8 wheel tank drive?
Here's my requirements for a good drivetrain (take it for what it's worth):
1> It must be controllable -- Having a robot that can go 20'/sec doesn't help if it's uncontrollable.
2> It must satisfy the games objective and teams strategy -- Being able to push a tank across the field does no good if there is no tank to push. Look at the game and its requirements and design for that.
3> The controls must be intuitive -- The driver will be ineffective if he has to constantly look at his controls and not the playing field.
4> It must be reliable -- It makes no difference if you have the greatest crab/swerve/omni/14-wheel drive if it is constantly breaking. The kitbot drivetrain is reliable enough to take you where you need to go.
5> It must be maintainable -- Things happen, and even the most reliable drivetrain can be damaged. If you cannot fix it during the competition (IE fast) then you need to rethink some of what you are doing. Unmaintainable leads to uninspiring.
You'll note that I did not discuss type of drivetrain, this is because that is very game specific. The best drivetrain is the one that accomplishes the job at hand, regardless of its configuration.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
What does it take to run an off season? keehun Off-Season Events 12 28-04-2009 08:50
What does it take to brick an RCX (no pun intended)? Billfred Lego Mindstorm Discussion 11 11-06-2007 12:25
what does it take to start a qualifier Dantvman27 FIRST Lego League 3 17-04-2007 14:59
What does it take to be considered and elite team? Jim Schaddelee General Forum 20 24-06-2005 10:59
