Go to Post We built an ineffective machine, all by ourselves! Yay for us! - Alan Anderson [more]
View Poll Results: How do you make your robot?
Just kit of parts 4 2.96%
Kit and 8020 21 15.56%
Welded square stock 38 28.15%
Sheet metal (outside manufacture) 20 14.81%
Sheet metal (we cut the parts) 13 9.63%
Other 39 28.89%
Voters: 135. You may not vote on this poll
Unread 02-05-2010, 19:30
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
How Do You Make Your Robot?
Since the start of 2228 we've been relying mostly on the kit parts and 8020 (a prototyping building material) to build our robots, and I'm starting to see more and more problems with building this way. 8020 is a prototyping material and it allows you to make quick changes and to guesstemate a lot of things and still be able to get it right. Which at first sounds good, but I've noticed more and more that because we can do those things we've become reliant on them and we don't design as thoroughly as we should be.
So my question to the FIRST community is how do you guys build your robot, do you do what we do and use 8020 (or a similar material), do you make it out of sheet metal, if make it out of sheet metal do you send the designs out and get parts back, do you make the parts yourself, do you weld your frames out of square stock, what?
I'm trying to figure out what are some of the things we can change to improve ourselves and get an idea of what other teams are doing. The only other solution I have in mind right now is to do something similar to the Thunderchickens (217) and Robowranglers (148).
There's a poll included in this thread, but I don't think it will be able to grasp the scope of the differences between teams.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
How would you have built your team's robot differently if the robot could expand? Chris is me General Forum 23 23-04-2009 06:50
How do you make the robot turn a perfect 90 eccmaster Programming 2 16-01-2008 20:54
How did you make your team insignia? vivek16 General Forum 8 24-02-2007 00:20
How do you make your compressorless system work, when all valves "bleed" air slowly? kmcclary Pneumatics 9 17-02-2007 21:01
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
