Go to Post They had me at "chocolate-covered bacon".... - Foster [more]
View Poll Results: How do you make your robot?
Just kit of parts 4 2.96%
Kit and 8020 21 15.56%
Welded square stock 38 28.15%
Sheet metal (outside manufacture) 20 14.81%
Sheet metal (we cut the parts) 13 9.63%
Other 39 28.89%
Voters: 135. You may not vote on this poll
Unread 19-05-2010, 10:14
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: How Do You Make Your Robot?
Originally Posted by CENTURION View Post
Team 1306 uses mostly the C-channel from the KOP and 80/20, but also angle aluminum, flat aluminum (1" width for both), plexi, aluminum plate, a bit of PVC, and (as a last resort only) plywood
This year's robot contained all of the above (I hated having to use the wood to mount electronics and penumatics, but we were short of time)
Just a quick comment; Wood, when used properly, can be an effective solution to a problem.
Unread 19-05-2010, 10:27
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
One of my firends favorite quotes:
Wood, its natures carbon fiber!
When you look at it that way, it is a much more attractive option.
Unread 20-05-2010, 09:46
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Yes, I guess so, I'm more worried about looks (I'm the teams *unofficial* lead graphic designer, and I'm terribly OCD about things like that)
Unread 20-05-2010, 09:58
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Im going to have to question your comment about wood not looking good
http://picasaweb.google.com/lh/photo...eat=directlink
Mentor 2415
Unread 20-05-2010, 11:31
FRC #0079
Rookie Year: 2000
Say what? Can you tell me which parts of those twins are wood and which aren't? Looks pretty good to me.
Eric reminded me, http://www.chiefdelphi.com/media/photos/31598 Quite possibly one of the most visually appealing frames I have seen in a while.
Unread 20-05-2010, 15:14
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Can you tell what parts of this are wood/not wood just by looking?
http://www.chiefdelphi.com/media/photos/32851 http://www.chiefdelphi.com/media/photos/32671
And, does it not look good?
I don't think there are any pictures out there of 330's underside in 2007, but if you looked at it, it was wood, hogged out to reduce weight. (Areas connecting fasteners remained at full thickness.) Other robots used wood baseplates; 2005 had a built-in notch to help interface with the frame.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
How would you have built your team's robot differently if the robot could expand? Chris is me General Forum 23 23-04-2009 06:50
How do you make the robot turn a perfect 90 eccmaster Programming 2 16-01-2008 20:54
How did you make your team insignia? vivek16 General Forum 8 24-02-2007 00:20
How do you make your compressorless system work, when all valves "bleed" air slowly? kmcclary Pneumatics 9 17-02-2007 21:01
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
