Go to Post Either way... woop! FRC is awesome! - Steven Smith [more]
Unread 02-05-2010, 22:50
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
2CAN C# Example
I have posted a Visual Studio 2005 C# example that can be used to control Jaguars using only a 2CAN. The app sockets to the 2CAN and sends voltage throttles over UDP. The 2CAN then in turn updates the Jaguars on the bus. The throttles are read from an attached USB Gamepad or Joystick. This is basically the example that was demoed at the AndyMark booth at Atlanta.
The entire solution (with release built exe) can be downloaded by clicking the "C# Application Example (Updated 5/2/2010)" link at...
http://www.crosstheroadelectronics.com/2CAN.htm
For those of you interested in creating your own apps I recommend looking at 2CANComm.cs as it has the c# and C style definition of the data sent to the 2CAN. A formal communication spec is in the works. Hopefully this will suffice in the meantime.
Be sure to use the non-FIRST Jaguar firmware. I have been using Jaguar version 5450 and 2CAN version 1.6. Also be sure to read through the ReadMe.txt file as it contains important information for compiling/debugging the C# app.
Unread 09-05-2010, 00:36
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: 2CAN C# Example
I have build a java command line program that does the same thing but without direct-x, joysticks, or a GUI. Source will be released soon!
Unread 09-05-2010, 17:53
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Rookie Year: 2007
Robototes2412 is on a distinguished road
Re: 2CAN C# Example
you can control can with something like an arduino, right?
Unread 09-05-2010, 19:45
AKA: Bryant
Re: 2CAN C# Example
As long as you can send serial data then I do not see why not. You have to remember though, the Jags are looking for a packet and if none is received within a 100ms time period they trip the watchdog which disables them. There is a pdf that describes the packet structure on the manufacturers website.
OTOH I would recommend using a 2CAN instead because it handles just about all of the conversions for you!
Unread 10-05-2010, 10:51
1 * 4 != 14
Rookie Year: 2007
Re: 2CAN C# Example
can has link?
Unread 10-05-2010, 11:11
1 * 4 != 14
Rookie Year: 2007
Re: 2CAN C# Example
Never mind, remember to read the frakken thread in the future
Unread 12-05-2010, 12:26
David Doerr's Avatar
David Doerr David Doerr is offline
FRC #4478 (Materia Oscura)
David Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud of
Re: 2CAN C# Example
Originally Posted by ozrien View Post
Be sure to use the non-FIRST Jaguar firmware. I have been using Jaguar version 5450...
Omar,
Where can one obtain the non-FIRST Jaguar firmware?
Does the non-FIRST firmware have working support for current-control and speed-control modes? (Apparently there were bugs that were fixed in FIRST version 91.)
Would it be possible to include a compiled proprietary module that could be used with one's own PC-based software -- like the C# software you've posted -- so that you wouldn't have to switch firmware when changing from cRIO-based to PC-based control (and back again)? That way trusted mode could be used with PC-based control without spilling the beans on trusted mode.
Thanks,
Dave
Unread 12-05-2010, 17:40
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Re: 2CAN C# Example
The built in HTTP server in the 2CAN works really well also. Just hit the 2CAN IP address with a browser and you get all sorts of nice stuff.
Unread 12-05-2010, 17:52
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Re: 2CAN C# Example
The non-FRC firmwares are included in the freely available development software from TI - there are separate ones for the grey Jags and black Jags.
Grey Jag kit: http://www.luminarymicro.com/products/rdk_bdc.html
Black Jag kit: http://www.luminarymicro.com/products/rdk_bdc24.html
Scroll down to the "Software Updates" section of those pages, and you'll see download links for the Firmware Development Package Software - you need to register to download. After you install the software, you'll see the firmware sources and binaries under INSTALL_DIR\boards\rdk-bdcXX. The Grey Jag firmware is qs-bdc; the Black Jag firmware is qs-bdc24.
Latest rev of the non-FRC firmwares is apparently 5961; the latest we've used is 5821 but have never had problems with any of the control modes in any of the non-FRC firmware.
As a side note our team (#2607) also ported the 2CAN cRIO plugin to run under Windows, and we use that to control the 2CAN from the PC. We've requested a firstforge project to post the code but it hasn't been approved/created yet.
Hope that helps!
- Ron
Team #2607 controls mentor
Unread 12-05-2010, 21:44
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Team Role: Coach
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
Re: 2CAN C# Example
Often the mechanical folks want to test some aspect of the robot without asking the software folks to stop what they're doing and write a little test program.
If someone is industrious it would be great to have a windows program that you could load on a laptop to control of all the Jaguars on the bus without needing to have the cRIO involved.
Even better would be for the 2CAN web interface itself to allow you to set direction and power settings for various Jaguars.
2016 PNW Championship Chairman's; 2016 Winner Oregon City District, 2015 PNW Championship Chairman's; 2015 PNW District Engineering Inspiration; 2015 PNW District Finalist; 2014 PNW Championship Chairman's; 2014 Championship Innovation in Controls; 2013 Chairman's (Oregon); 2013 Finalist (OKC); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2011 Volunteer of the Year (Oregon); 2011 Finalist & Captain (San Diego); 2011 Innovation in Control (San Diego); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2010 Innovation in Control (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2008 Regional Champions (Oregon); 2007 Regional Finalist (Oregon); 2005 Rookie Inspiration (PNW)
Unread 12-05-2010, 22:53
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: 2CAN C# Example
For Serial bridge users that would be BDC-Comm (a little hard to use). For 2CAN jags that's not really possible without doing re-flashing of all of them for that one test and then re-flashing them to work with the cRIO (which means even more programmer time) because of the safety system put in by FIRST
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 12-05-2010, 23:41
Peter Johnson Peter Johnson is online now
WPILib Developer
FRC #0294 (Beach Cities Robotics)
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: 2CAN C# Example
I've successfully driven FIRST firmware jags with BDC-Comm, at least in voltage/%speed mode (current mode doesn't seem to work). Oops, re-read your post; you're right that over 2CAN it doesn't work with FIRST firmware.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
2CAN API Dweller CAN 4 12-03-2011 21:07
2CAN vs. Serial-to-CAN ajd CAN 9 24-04-2010 21:33
Plugin update for 2CAN ozrien CAN 3 01-02-2010 16:26
2CAN Plugin Released Mike Copioli Control System 16 24-01-2010 03:31
Legality of the 2CAN Geek 2.0 FRC Control System 9 19-01-2010 20:51
