Go to Post I wonder if Radio Shacks all over should prepare for VEX robots dropping by for spare parts just like people going to a medical clinic... - Wayne C. [more]
Unread 04-05-2010, 09:26
blhenze blhenze is offline
Bernie H
FRC #2333 (Sapulpa Chieftain Robotics)
Team Role: Teacher
blhenze is an unknown quantity at this point
Can No Longer Communicate
After coming back from the regional, we unpacked the robot and stored it in a corner. Two weeks ago we received a request to demo the robot at the Lion's organization. When we fired it up, it started doing all kinds of weird things (devices running at startup with no autonomous code). As long as we were tethered to the cRIO everything worked. However, there is no communications between our router and the wireless bridge on the robot or the wireless bridge and our computer.
I suspect that the update of the Wireless bridge at regional is now stopping us from communicating with the robot. Has anyone else experienced anything similar?
Unread 04-05-2010, 09:33
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Can No Longer Communicate
your wireless bridge still has the encrypted key used for you regional. You will need to clear it.
Ed Barker
Unread 04-05-2010, 10:04
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
I'm with Ed on resetting the Regional's wireless bridge security.
Here's a previous post discussing what to do.
There's something really wrong though if your robot starts running as soon as you turn it on without the Driver Station enabling it.
Any more detail about that, preferably the simplest series of steps to get it to do that?
E.g., 1) Driver Station disconnected, 2) robot power main breaker switched on, 3) robot starts moving.
Unread 04-05-2010, 11:33
Bernie H
Team Role: Teacher
Thanks for the replys - Bernie
Unread 04-05-2010, 12:35
Bernie H
Team Role: Teacher
After resetting the router, bridge, and pc, and then reconfiguring everything, the bridge doesn't seem to be working (the Wireless part).
Using Ethernet cables I connected the bridge directly to the PC. I reset the appropriate IP Address and made sure there weren't any security settings. I connected the bridge to the router and the PC to the router and I could ping the router, bridge, & PC. I tethered to the cRIO and it pinged.
I then hooked up everything for wireless. I could ping the router but not the bridge. I'm beginning to believe there is a problem with the bridge.
Any suggestions?
Unread 04-05-2010, 18:24
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Did you follow the wireless setup instructions in Chapter 2 of the control system manual after resetting both the router and the bridge?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
cRIO Does Not Communicate, Yet Can Be Pinged and Re-Imaged 1951-44U FRC Control System 7 15-12-2009 21:25
No longer can build with Lab View after downloading update 3. shaggy0928 NI LabVIEW 2 14-03-2009 10:03
RC will not communicate with OI Ryank Electrical 3 08-01-2008 17:00
Can't communicate w/ cam obeyken Programming 2 20-07-2005 21:04
Speed controllers won't communicate w/robot controller steven114 Control System 12 03-02-2005 21:26
