Go to Post This isn't about practical, it's about having fun and thinking outside the box... tetrahedron.... whatever....:rolleyes: - Cyberguy34000 [more]
Unread 05-05-2010, 13:09
infocus infocus is offline
infocus is an unknown quantity at this point
CAN programming on labview- Speed Control
Here is our configuration- We have the black jaguar already networked to our other 3 grey jaguars. The network works properly. We have 4 toughboxes and encoders from andy mark, connected to mechanum wheels. We replaced all the standard jaguar VI's with the CAN VIs. The robot operates the same as it did with PWMs. We would like to use CAN for speed control to improve our traction and to keep ourselves from being pushed around the field. We did look at the speed control example VI but it says it cannot find the control named "Speed PID Controller status data.ctl" and asks us to find it and without this it will not open.
In our original robot code, we had the ability to switch from Tank to mechanum. We would like to use speed control for both of these. Any advice would be greatly appreciated, as we are relatively new to Labview, and especially CAN.
Help with CAN bus closed-loop speed control RoboGuy Programming 16 14-04-2010 12:34
Gray Jaguar CAN closed-loop speed control Ether CAN 6 13-04-2010 23:10
can we control the amount of air to control the speed of the cylinder? Team2339 Pneumatics 22 11-02-2009 15:33
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Where can i Find info on the control programming Matchew General Forum 1 14-01-2002 19:09
